Configure Script
I would like to export the configuration using say /export file=fred and use it as the default via the “configure script” when doing a netinstall.
I have cleaned up an export and it will work fine if I past it via a terminal but it will not work as a configure script via netinstall.
Is it possible to get a copy of the default that is used if a configure script is not specified?
If not does anyone have a sugestion for debugging the Configure script option? Does it realy work?
thanks
Lee McLaren
there is no default. there are many people who use the netinstall option, so it does work. show us the script, maybe there is a problem.
also - this is a user forum, mikrotik does not guarantee that it will monitor or answer the posts here.
Thankyou for replying Normis,
The script below was created by doing an /export backup and copying the file off, then used as the configure script using netinstall, the s/w version is 2.9.25 on a rb112.
After a restart none of the setting too hold, no scripts, no ip addresses, no pptp client etc.
I am using the same hardware each time.
Using winbox I connected via MAC address, opened a new terminal and pasted the same script and it applied all the settings correctly.
#Script start ##################################
jan/04/2000 03:26:15 by RouterOS 2.9.25
software id = JD1G-3TT
/ interface ethernet
set ether1 name="ether1" mtu=1500 mac-address=00:0C:42:08:82:AC arp=enabled
disable-running-check=yes auto-negotiation=yes full-duplex=yes
cable-settings=default speed=100Mbps comment="" disabled=no
/ interface wireless
set wlan1 name="wlan1" mtu=1500 mac-address=00:0B:6B:37:B2:51 arp=enabled
disable-running-check=no radio-name="notset" mode=ap-bridge ssid="hotspot"
area="" frequency-mode=manual-txpower country=no_country_set
antenna-gain=0 frequency=2412 band=2.4ghz-b/g scan-list=default
rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no
security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms
preamble-mode=both compression=no allow-sharedkey=no comment=""
disabled=no
/ interface wireless nstreme
set wlan1 enable-nstreme=no enable-polling=yes framer-policy=none
framer-limit=3200
/ interface wireless manual-tx-power-table
set wlan1 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp
s:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
/ interface wireless security-profiles
set default name="default" mode=none authentication-types=""
unicast-ciphers="" group-ciphers="" wpa-pre-shared-key=""
wpa2-pre-shared-key="" eap-methods=passthrough tls-mode=no-certificates
tls-certificate=none static-algo-0=none static-key-0="" static-algo-1=none
static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none
static-key-3="" static-transmit-key=key-0 static-sta-private-algo=none
static-sta-private-key="" radius-mac-authentication=no group-key-update=5m
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=no
audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no
frames-per-second=25 audio-min=-100 audio-max=-20
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no
memory-limit=10 file-name="" file-limit=10 streaming-enabled=no
streaming-server=0.0.0.0 streaming-max-rate=0
/ interface l2tp-server server
set enabled=no max-mtu=1460 max-mru=1460
authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption
/ interface pptp-server server
set enabled=no max-mtu=1460 max-mru=1460 authentication=mschap1,mschap2
keepalive-timeout=30 default-profile=default-encryption
/ interface pptp-client
add name="pptp-out1" max-mtu=1460 max-mru=1460 connect-to=172.19.254.254
user="test" password="password" profile=default-encryption
add-default-route=no allow=pap,chap,mschap1,mschap2 disabled=no
/ ip ipsec proposal
add name="default" auth-algorithms=sha1 enc-algorithms=3des lifetime=30m
lifebytes=0 pfs-group=modp1024 disabled=no
/ ip dhcp-client
add interface=ether1 add-default-route=yes use-peer-dns=yes use-peer-ntp=yes
/ ip dhcp-server config
set store-leases-disk=5m
/ ip hotspot service-port
set ftp ports=21 disabled=no
/ ip hotspot profile
set default name="default" hotspot-address=0.0.0.0 dns-name=""
html-directory=hotspot rate-limit="" http-proxy=0.0.0.0:0
smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d
split-user-domain=no use-radius=no
/ ip hotspot user profile
set default name="default" idle-timeout=none keepalive-timeout=2m
status-autorefresh=1m shared-users=1 transparent-proxy=yes
open-status-page=always advertise=no
/ ip proxy
set enabled=no src-address=0.0.0.0 port=8080 parent-proxy=0.0.0.0:0
cache-administrator="webmaster" max-disk-cache-size=none
max-ram-cache-size=unlimited cache-only-on-disk=no
maximal-client-connections=1000 maximal-server-connections=1000
max-object-size=4096KiB max-fresh-time=3d
/ ip accounting
set enabled=no account-local-traffic=no threshold=256
/ ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
/ ip service
set telnet port=23 address=0.0.0.0/0 disabled=no
set ftp port=21 address=0.0.0.0/0 disabled=no
set www port=80 address=0.0.0.0/0 disabled=no
set ssh port=22 address=0.0.0.0/0 disabled=no
set www-ssl port=443 address=0.0.0.0/0 certificate=none disabled=yes
/ ip upnp
set enabled=no allow-disable-external-interface=yes show-dummy-rule=yes
/ ip socks
set enabled=no port=1080 connection-idle-timeout=2m max-connections=200
/ ip dns
set primary-dns=172.19.254.254 secondary-dns=0.0.0.0 allow-remote-requests=no
cache-size=2048KiB cache-max-ttl=1w
/ ip traffic-flow
set enabled=no interfaces=all cache-entries=4k active-flow-timeout=30m
inactive-flow-timeout=15s
/ ip address
add address=192.168.254.254/24 network=192.168.254.0 broadcast=192.168.254.255
interface=wlan1 comment="" disabled=no
/ ip neighbor discovery
set ether1 discover=yes
set wlan1 discover=yes
set pptp-out1 discover=no
/ ip route
/ ip firewall connection tracking
set enabled=yes tcp-syn-sent-timeout=5s tcp-syn-received-timeout=5s
tcp-established-timeout=1d tcp-fin-wait-timeout=10s
tcp-close-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-time-wait-timeout=10s tcp-close-timeout=10s udp-timeout=10s
udp-stream-timeout=3m icmp-timeout=10s generic-timeout=10m
tcp-syncookie=no
/ ip firewall service-port
set tftp ports=69 disabled=no
set irc ports=6667 disabled=no
set h323 disabled=yes
set quake3 disabled=no
set mms disabled=no
set gre disabled=yes
set pptp disabled=yes
/ system ntp server
set enabled=no broadcast=no multicast=no manycast=yes
/ system ntp client
set enabled=no mode=unicast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/ system routerboard settings
set baud-rate=115200 boot-delay=1s boot-device=nand-if-fail-then-ethernet
enter-setup-on=any-key cpu-mode=power-save memory-test=no
cpu-frequency=175MHz boot-protocol=bootp enable-jumper-reset=yes
/ system logging
add topics=info prefix="" action=memory disabled=no
add topics=error prefix="" action=memory disabled=no
add topics=warning prefix="" action=memory disabled=no
add topics=critical prefix="" action=echo disabled=no
/ system logging action
set memory name="memory" target=memory memory-lines=100 memory-stop-on-full=no
set disk name="disk" target=disk disk-lines=100 disk-stop-on-full=no
set echo name="echo" target=echo remember=yes
set remote name="remote" target=remote remote=0.0.0.0:514
/ system upgrade mirror
set enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0
check-interval=1d user=""
/ system script
add name="RebootConfig" source="
\n
\n# Get MAC address as text for name into
NameTxt variable
\n:global NameRaw [/interface ethernet get ether1
mac-address]
\n:global NameTxt ([:pick $NameRaw 0 2] . [:pick
$NameRaw 3 5] . [:pick $NameRaw 6 8] . [:pick $NameRaw 9 11] .
[:pick $NameRaw 12 14] . [:pick $NameRaw 15 17])
\n# If the name is
not the same as NameTxt then set it.
\n:if ([/system identity get name]
!= $NameTxt) do= { /system identity set name= $NameTxt
\n :log info
"Setting Name" }
\n"
policy=ftp,reboot,read,write,policy,test,winbox,password
/ system clock dst
set dst-delta=+00:00 dst-start="jan/01/1970 00:00:00" dst-end="jan/01/1970
00:00:00"
/ system watchdog
set reboot-on-failure=yes watch-address=none watchdog-timer=yes
no-ping-delay=5m automatic-supout=yes auto-send-supout=no
/ system console
add port=serial0 term="" disabled=no
/ system identity
set name="Mikrotik"
/ system note
set show-at-login=yes note=""
/ system scheduler
add name="OnBoot" on-event=":delay 00:00:12
\n:log info "Script RebootConfig
Start"
\n/system script run RebootConfig
\n:log info "Script
RebootConfig End"" start-time=startup interval=0s comment="" disabled=no
/ port
set serial0 name="serial0" baud-rate=115200 data-bits=8 parity=none
stop-bits=1 flow-control=none
/ ppp profile
set default name="default" use-compression=default use-vj-compression=default
use-encryption=default only-one=default change-tcp-mss=yes comment=""
set default-encryption name="default-encryption" use-compression=default
use-vj-compression=default use-encryption=yes only-one=default
/ ppp aaa
set use-radius=no accounting=yes interim-update=0s
/ queue type
set default name="default" kind=pfifo pfifo-limit=50
set ethernet-default name="ethernet-default" kind=pfifo pfifo-limit=50
set wireless-default name="wireless-default" kind=sfq sfq-perturb=5
sfq-allot=1514
set synchronous-default name="synchronous-default" kind=red red-limit=60
red-min-threshold=10 red-max-threshold=50 red-burst=20 red-avg-packet=1000
set hotspot-default name="hotspot-default" kind=sfq sfq-perturb=5
sfq-allot=1514
add name="default-small" kind=pfifo pfifo-limit=10
/ user
add name="admin" group=full address=0.0.0.0/0 comment="system default user"
disabled=no
/ user group
add name="read" policy=local,telnet,ssh,reboot,read,test,winbox,password,web,!f
tp,!write,!policy
add name="write" policy=local,telnet,ssh,reboot,read,write,test,winbox,password
,web,!ftp,!policy
add name="full" policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbo
x,password,web
/ user aaa
set use-radius=no accounting=yes interim-update=0s default-group=read
/ tool bandwidth-server
set enabled=yes authenticate=yes allocate-udp-ports-from=2000 max-sessions=10
/ tool mac-server ping
set enabled=yes
/ tool e-mail
set server=0.0.0.0 from="<>"
/ tool sniffer
set interface=all only-headers=no memory-limit=10 file-name="" file-limit=10
streaming-enabled=no streaming-server=0.0.0.0 filter-stream=yes
filter-protocol=ip-only filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535
/ tool graphing
set store-every=5min
/ routing ospf
set router-id=0.0.0.0 distribute-default=never redistribute-connected=no
redistribute-static=no redistribute-rip=no redistribute-bgp=no
metric-default=1 metric-connected=20 metric-static=20 metric-rip=20
metric-bgp=20
/ routing ospf area
set backbone area-id=0.0.0.0 type=default translator-role=translate-candidate
authentication=none prefix-list-import="" prefix-list-export=""
disabled=no
/ routing bgp
set enabled=no as=1 router-id=0.0.0.0 redistribute-static=no
redistribute-connected=no redistribute-rip=no redistribute-ospf=no
/ routing rip
set redistribute-static=no redistribute-connected=no redistribute-ospf=no
redistribute-bgp=no metric-static=1 metric-connected=1 metric-ospf=1
metric-bgp=1 update-timer=30s timeout-timer=3m garbage-timer=2m
/ radius incoming
set accept=no port=1700
/ snmp
set enabled=no contact="" location=""
/ snmp community
set public name="public" address=0.0.0.0/0 read-access=yes
#Script End###########################
Has anyone managed to get the configure script to work? Has anyone a sample that I can build on?
Hey,
There seems to be a limitation of the size of the script used when doing the netinstall.
I have tried the same as you have and discovered it the hard way :frowning:
Try a script that is just a few lines and it will work.
If this is a bug in netinstall or in the ROS I don´t know.
I think MT guys need to look into it.
BR, Paul
we will check this
Hey, Normis.
Have you done any testing, if so when is a correction planned.
there is a limitation of 64KB, it can’t be increased, but the files are usually smaller than that. if not, try to remove some rules, and import them later via another file.
Normis:
I fail with scripts that have more than 29 lines, the file is only 2kB.
I´m using 2.9.38, can you please verify this problem.
I suggest you to weed that script from unnecessary lines. e.g. this one.
/ routing bgp
set enabled=no as=1 router-id=0.0.0.0 redistribute-static=no \
It is default configuration, it is even not used. Leave only those things that you have changed and are using.
Hey raivis-v,
The script in the thread isn´t provided from me, I have just make the statement that the scripting isn´t working efter 29 lines, try it yourself.
I doesn´t depend on the size of the script, of course Normis say 64kB, that´s a size limit, but when it it comes to line 30 it won´t accept the command and break the hole script.
has this limitation been overcome?
I have long script to use as default configuration, and it seems not working using netinstall, unless I use the reset configuration and run-after-reset function.
But I need to set it from netinstall to be the default configuration if my clients reset the device.
I am also interested in whether this problem has been solved. Can anyone offer any experiences?
