We had an oversight on a project today and did not get the necessary cabling to configure our new radios for 802.11n. Regardless, I need to get the link up today and configure “N” later. Is there a doc on how to configure the sR71 to use only one antenna? The far end radio is using a cm9. Not sure if that makes a difference as far as enabled features.
set for 802.11 bgn..
Set for only one chain.
Connect ant to primary connector..
It will connect to the far end (802.11g) just fine..
I wasn’t been able to make it work without MIMO.
http://forum.mikrotik.com/t/ubiquiti-sr71-a-sr71-15-need-consultation/38940/1
Strange…
I run the SR71e.. I use both chains, (two Ant), but B,G,N all connect just fine…
I will try it with one chain disabled and take a look..
