I have mikrotik router connected with broadband connection. Right now we don’t have any static IP but I have applied to get Static IP, so I’ll get static IP soon. As of now my mikrotik configuration is
I can access Mikrotik router from my system/private network by 192.168.2.1. Later on we are going to allow employees to work from home by RDP over VPN. For this I need one static IP for mikrotik router, then router will port mapping to individual systems. So I need to configure static IP for mikrotik router, how can I do this?. If I reset the above address list as
Will this setup work? Here I want my private network to be remain private with 192.168.2.2-192.168.2.100 IPs and the mikrotik router would have static IP, so that I can access mikrotik router from anywhere.
I got static IP and trying to configure in mikrotik router. Check this link http://forum.mikrotik.com/t/problem-connecting-mikrotik-router-with-broadband-connection/75570/1 which describes problems that I faced while configure pppoe in mikrotik router and resolved it. Now after I got static IP, I configured static IP as @rextended said, the moment I configured Static IP in address it turned into red color(means Invalid ) then
I changed pppoe-out to ether1-Input in the address rule
Disabled pppoe-out entry in ppp.
Changed NAT rule’s out-interface from pppoe-out to ether1-Input .
Right now my configuration are
[niren@MikroTik] > ip address print
# ADDRESS NETWORK INTERFACE
0 192.168.2.1/24 192.168.2.0 ether2
1 xxx.xxx.18.153/22 xxx.xxx.16.0 ether1-Input
[niren@MikroTik] > interface print
# NAME TYPE MTU L2MTU MAX-L2MTU
0 R ether1-Input ether 1500 1598 4074
1 R ether2 ether 1500 1598 4074
2 X pppoe-out pppoe-out
[niren@MikroTik] > ip firewall nat print
0 ;;; srcnat LAN private IP's traffic to be masquerade
chain=srcnat action=masquerade to-addresses=xxx.xxx.16.1
src-address=192.168.2.0/24 out-interface=ether1-Input
[niren@MikroTik] > ip dns print
servers: xxx.xxx.21.12,xxx.xxx.20.101
dynamic-servers:
allow-remote-requests: no
max-udp-packet-size: 4096
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 8KiB
I don’t use username and password which are given by internet provider. Now I can able to ping gatway of wan network from my system which is connected to mikrotik router.
C:\Users\niren>ping xxx.xxx.16.1
Pinging xxx.xxx.16.11 with 32 bytes of data:
Request timed out.
Reply from xxx.xxx.16.1: bytes=32 time=1ms TTL=254
But unable to connect to internet
C:\Users\niren>ping 8.8.8.8
Pinging 8.8.8.8 with 32 bytes of data:
Request timed out.
Reply from 192.168.2.1: Destination net unreachable.
I can’t even ping dns address. Any help? I need to configure this quickly.
my Ethernet1 on Mikrotik was connected to the Yellow port on a TP-LINK DSL and Mikrotik was configured to dial out using PPPoE Client. I used to get the Dynamic IP and then i used NAT (Masquerade) in Mikrotik to make my life complete. WHOA!!! Honey I got Internet…
that was history… now i have a Static IP from the ISP.
i just fail to understand where to put the Static IP in Mikrotik PPPoE Client (Dial-up) option because I still need to use the dial-up part to connect to the ISP.
the only difference is I now i have a Fixed IP from the ISP…
Aaah, I just thought how about disabling the DHCP client on that specific interface, but I just checked one of my test systems and found out that DHCP client can not be bound to a PPPoE client interface. I assume that it will grab an IP automatically.
Isn’t your ISP supplying you with your static assigned IP the moment your PPPoE comes online?
I can remember from the past when I was on PPPoE that it was like that.
Guys - a static IP address on a PPPoE connection just means that they’ll always be assigning you the same address.
Do nothing.
Sip some coffee or tea.
The address is now static.
Worst case - after they update your AAA profile on their end, you have to disconnect and reconnect to receive the new static-assigned address. (they may even bounce the connection from their end). PPPoE is designed to negotiate the local and remote addresses. The most you can do by configuring your end with a static IP address is basically telling your router: don’t agree to any address but this one. If they give something else, then hang up and dial again. In other words, you’d rather be DOWN than UP with the wrong IP.
It’s like getting a static lease in DHCP - the client device doesn’t need to do anything special to get the same address all the time. It just needs to continue being the same device (MAC address).
I am trying to migrate from a D-Link DIR-615 to RB951G-2HnD
I am given the following static IP by my ISP: 17x.x.x.137/30 which gives me 2 usable Public IPs. Authentication is via PPPoE which needs to be on vlan ID 500.
The current setup is that the D-Link’s Public IP is 17x.x.x.137 and the first Ethernet port will assign 17x.x.x.138 to whatever is connected.
In the D-link the setup is simple:
Static PPPoE
User Name: xxx@xxx
Password: xxx
IP Address: 17x.x.x.137
IP Netmask: 255.255.255.252
LAN Start IP: 17x.x.x.138
LAN End IP: 17x.x.x.138
On the Mikrotik, I created the VLAN interface and can connect to the ISP and receive the static IP Address: 17x.x.x.137 as expected.
How do I set ether2 to be allowed to use 17x.x.x.138?
From my understanding I have to put the PPPoE interface on a bridge with the ether2 interface, but I can’t do that. Any help is appreciated.
I managed to solve my problem. I created a bridge to bridge ether1 (where the pppoe interface is) and ether2.
I applied the static IP given by the ISP on this bridge (17x.x.x.137/30).
My server/firewall which is configured as 17x.x.x.138/30 connected to ether2 now works.
So the answer was to bridge the physical interface where the pppoe virtual interface was located.
