Hi guys
I’m a bit confused here, and also I’m new to working with MikroTik…
I have managed to configure hotspot + RADIUS using the wiki here, but I got to a point where I make the test but the MT is unable to authenticate the user from the AD I told it to connect to…
And it tells me every time I type the active directory user name and password in the hotspot login page that the RADIUS server is not responding…
Below is my configuration taken from my test device:
[admin@MikroTik] > export
# feb/11/2014 18:23:21 by RouterOS 5.25
# software id = W5EY-LHT9
set 0 arp=enabled auto-negotiation=yes cable-settings=default \
disable-running-check=yes disabled=no full-duplex=yes mac-address=\
00:0C:29:C2:AE:70 mtu=1500 name=wlan1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes cable-settings=default \
00:0C:29:C2:AE:7A mtu=1500 name=wlan2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes cable-settings=default \
00:0C:29:C2:AE:84 mtu=1500 name=wlan3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes cable-settings=default \
00:0C:29:C2:AE:8E mtu=1500 name=wlan4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes cable-settings=default \
00:0C:29:C2:AE:98 mtu=1500 name=wlan5 speed=100Mbps
set 5 arp=enabled auto-negotiation=yes cable-settings=default \
00:0C:29:C2:AE:A2 mtu=1500 name=wlan6 speed=100Mbps
set 6 arp=enabled auto-negotiation=yes cable-settings=default \
00:0C:29:C2:AE:AC mtu=1500 name=wlan7 speed=100Mbps
set 7 arp=enabled auto-negotiation=yes cable-settings=default \
00:0C:29:C2:AE:B6 mtu=1500 name=wlan8 speed=100Mbps
set 8 arp=enabled auto-negotiation=yes cable-settings=default \
00:0C:29:C2:AE:C0 mtu=1500 name=wlan9 speed=100Mbps
set 9 arp=enabled auto-negotiation=yes cable-settings=default \
00:0C:29:C2:AE:CA mtu=1500 name=lan speed=100Mbps
set [ find default=yes ] authentication-types="" eap-methods=passthrough \
group-ciphers=aes-ccm group-key-update=5m interim-update=0s \
management-protection=disabled management-protection-key="" mode=none name=\
default radius-eap-accounting=no radius-mac-accounting=no \
radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=\
XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none \
static-algo-1=none static-algo-2=none static-algo-3=none static-key-0="" \
static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=\
none static-sta-private-key="" static-transmit-key=key-0 \
supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates \
unicast-ciphers=aes-ccm wpa-pre-shared-key="" wpa2-pre-shared-key=""
/ip hotspot profile
set [ find default=yes ] dns-name=mikrotik.com hotspot-address=192.168.2.12 \
html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 \
login-by=cookie,http-pap name=default rate-limit="" smtp-server=0.0.0.0 \
split-user-domain=no use-radius=no
add dns-name=mikrotik.com hotspot-address=192.168.2.12 html-directory=hotspot \
http-proxy=0.0.0.0:0 login-by=http-pap name=mikrotik nas-port-type=\
wireless-802.11 radius-accounting=yes radius-default-domain="" \
radius-interim-update=received radius-location-id="" radius-location-name=\
"" radius-mac-format=XX:XX:XX:XX:XX:XX rate-limit="" smtp-server=0.0.0.0 \
split-user-domain=no use-radius=yes
/ip hotspot
add disabled=no idle-timeout=none interface=lan keepalive-timeout=none name=\
mikrotik profile=mikrotik
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default \
shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des \
lifetime=30m name=default pfs-group=modp1024
add name=dhcp_pool1 ranges=10.10.10.2-10.10.10.254
/port
set 0 baud-rate=9600 data-bits=8 flow-control=none name=serial0 parity=none \
stop-bits=1
set 1 baud-rate=9600 data-bits=8 flow-control=none name=serial1 parity=none \
stop-bits=1
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default remote-ipv6-prefix-pool=\
none use-compression=default use-encryption=default use-ipv6=yes use-mpls=\
default use-vj-compression=default
set 1 change-tcp-mss=yes name=default-encryption only-one=default \
remote-ipv6-prefix-pool=none use-compression=default use-encryption=yes \
use-ipv6=yes use-mpls=default use-vj-compression=default
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=none name=only-hardware-queue
set 6 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 7 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \
ignore-as-path-len=no name=default out-filter="" redistribute-connected=no \
redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=ospf-in \
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto \
metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
backbone type=default
/routing ospf-v3 instance
set [ find default=yes ] disabled=no distribute-default=never metric-bgp=auto \
metric-connected=20 metric-default=1 metric-other-ospf=auto metric-rip=20 \
metric-static=20 name=default redistribute-bgp=no redistribute-connected=no \
redistribute-other-ospf=no redistribute-rip=no redistribute-static=no \
router-id=0.0.0.0
/routing ospf-v3 area
/snmp community
set [ find default=yes ] addresses="" authentication-password="" \
authentication-protocol=MD5 encryption-password="" encryption-protocol=DES \
name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=:: remote-port=514 src-address=0.0.0.0 \
syslog-facility=daemon syslog-severity=auto target=remote
/tool user-manager customer
add backup-allowed=yes disabled=no login=admin password="" \
paypal-accept-pending=no paypal-allowed=no paypal-secure-response=no \
permissions=owner signup-allowed=no time-zone=-00:00
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,web\
,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pass\
word,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,wi\
nbox,password,web,sniff,sensitive,api" skin=default
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption \
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\
default enabled=no keepalive-timeout=60 mac-address=FE:0D:37:91:A1:72 \
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=\
yes keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\
disabled port=443 verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no \
streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.31.21/24 disabled=no interface=wlan1 network=192.168.31.0
add address=192.168.32.21/24 disabled=no interface=wlan2 network=192.168.32.0
add address=192.168.33.21/24 disabled=no interface=wlan3 network=192.168.33.0
add address=192.168.34.21/24 disabled=no interface=wlan4 network=192.168.34.0
add address=192.168.35.21/24 disabled=no interface=wlan5 network=192.168.35.0
add address=192.168.36.21/24 disabled=no interface=wlan6 network=192.168.36.0
add address=192.168.37.21/24 disabled=no interface=wlan7 network=192.168.37.0
add address=192.168.38.21/24 disabled=no interface=wlan8 network=192.168.38.0
add address=192.168.39.21/24 disabled=no interface=wlan9 network=192.168.39.0
add address=192.168.2.12/24 comment=Management disabled=no interface=lan \
network=192.168.2.0
/ip dhcp-server config
set store-leases-disk=5m
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB \
max-udp-packet-size=4096 servers=10.54.23.65,86.111.144.194
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=\
10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s \
udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" \
disabled=yes
/ip firewall mangle
add action=mark-connection chain=input disabled=no in-interface=wlan1 \
new-connection-mark=wlan1_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=wlan2 \
new-connection-mark=wlan2_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=wlan3 \
new-connection-mark=wlan3_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=wlan4 \
new-connection-mark=wlan4_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=wlan5 \
new-connection-mark=wlan5_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=wlan6 \
new-connection-mark=wlan6_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=wlan7 \
new-connection-mark=wlan7_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=wlan8 \
new-connection-mark=wlan8_conn passthrough=yes
add action=mark-connection chain=input disabled=no in-interface=wlan9 \
new-connection-mark=wlan9_conn passthrough=yes
add action=mark-routing chain=output connection-mark=wlan1_conn disabled=no \
new-routing-mark=wlan1 passthrough=yes
add action=mark-routing chain=output connection-mark=wlan2_conn disabled=no \
new-routing-mark=wlan2 passthrough=yes
add action=mark-routing chain=output connection-mark=wlan3_conn disabled=no \
new-routing-mark=wlan3 passthrough=yes
add action=mark-routing chain=output connection-mark=wlan4_conn disabled=no \
new-routing-mark=wlan4 passthrough=yes
add action=mark-routing chain=output connection-mark=wlan5_conn disabled=no \
new-routing-mark=wlan5 passthrough=yes
add action=mark-routing chain=output connection-mark=wlan6_conn disabled=no \
new-routing-mark=wlan6 passthrough=yes
add action=mark-routing chain=output connection-mark=wlan7_conn disabled=no \
new-routing-mark=wlan7 passthrough=yes
add action=mark-routing chain=output connection-mark=wlan8_conn disabled=no \
new-routing-mark=wlan8 passthrough=yes
add action=mark-routing chain=output connection-mark=wlan9_conn disabled=no \
new-routing-mark=wlan9 passthrough=yes
add action=mark-connection chain=prerouting disabled=no dst-address-type=!local \
in-interface=lan new-connection-mark=wlan1_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:9/0
in-interface=lan new-connection-mark=wlan2_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:9/1
in-interface=lan new-connection-mark=wlan3_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:9/2
in-interface=lan new-connection-mark=wlan4_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:9/3
in-interface=lan new-connection-mark=wlan5_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:9/4
in-interface=lan new-connection-mark=wlan6_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:9/5
in-interface=lan new-connection-mark=wlan7_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:9/6
in-interface=lan new-connection-mark=wlan8_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:9/7
in-interface=lan new-connection-mark=wlan9_conn passthrough=yes \
per-connection-classifier=both-addresses-and-ports:9/8
add action=mark-routing chain=prerouting connection-mark=wlan1_conn disabled=no \
in-interface=lan new-routing-mark=wlan1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=wlan2_conn disabled=no \
in-interface=lan new-routing-mark=wlan2 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=wlan3_conn disabled=no \
in-interface=lan new-routing-mark=wlan3 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=wlan4_conn disabled=no \
in-interface=lan new-routing-mark=wlan4 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=wlan5_conn disabled=no \
in-interface=lan new-routing-mark=wlan5 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=wlan6_conn disabled=no \
in-interface=lan new-routing-mark=wlan6 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=wlan7_conn disabled=no \
in-interface=lan new-routing-mark=wlan7 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=wlan8_conn disabled=no \
in-interface=lan new-routing-mark=wlan8 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=wlan9_conn disabled=no \
in-interface=lan new-routing-mark=wlan9 passthrough=yes
disabled=yes
add action=masquerade chain=srcnat connection-mark=wlan1_conn disabled=no \
out-interface="(unknown)"
add action=masquerade chain=srcnat connection-mark=wlan2_conn disabled=no \
add action=masquerade chain=srcnat connection-mark=wlan3_conn disabled=no \
add action=masquerade chain=srcnat connection-mark=wlan4_conn disabled=no \
add action=masquerade chain=srcnat connection-mark=wlan5_conn disabled=no \
add action=masquerade chain=srcnat connection-mark=wlan6_conn disabled=no \
add action=masquerade chain=srcnat connection-mark=wlan7_conn disabled=no \
add action=masquerade chain=srcnat connection-mark=wlan8_conn disabled=no \
add action=masquerade chain=srcnat connection-mark=wlan9_conn disabled=no \
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip hotspot user
add disabled=no name=admin password=admin2 profile=default
/ip neighbor discovery
set wlan1 disabled=yes
set wlan2 disabled=yes
set wlan3 disabled=yes
set wlan4 disabled=yes
set wlan5 disabled=yes
set wlan6 disabled=yes
set wlan7 disabled=yes
set wlan8 disabled=yes
set wlan9 disabled=yes
set lan disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \
cache-on-disk=no enabled=no max-cache-size=unlimited \
max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=no \
src-address=0.0.0.0
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
"(unknown)" routing-mark=wlan1 scope=30 target-scope=10
"(unknown)" routing-mark=wlan2 scope=30 target-scope=10
"(unknown)" routing-mark=wlan3 scope=30 target-scope=10
"(unknown)" routing-mark=wlan4 scope=30 target-scope=10
"(unknown)" routing-mark=wlan5 scope=30 target-scope=10
"(unknown)" routing-mark=wlan6 scope=30 target-scope=10
"(unknown)" routing-mark=wlan7 scope=30 target-scope=10
"(unknown)" routing-mark=wlan8 scope=30 target-scope=10
"(unknown)" routing-mark=wlan9 scope=30 target-scope=10
"(unknown)" scope=30 target-scope=10
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
add check-gateway=ping disabled=no distance=3 dst-address=0.0.0.0/0 gateway=\
add check-gateway=ping disabled=no distance=4 dst-address=0.0.0.0/0 gateway=\
add check-gateway=ping disabled=no distance=5 dst-address=0.0.0.0/0 gateway=\
add check-gateway=ping disabled=no distance=6 dst-address=0.0.0.0/0 gateway=\
add check-gateway=ping disabled=no distance=7 dst-address=0.0.0.0/0 gateway=\
add check-gateway=ping disabled=no distance=8 dst-address=0.0.0.0/0 gateway=\
add check-gateway=ping disabled=no distance=9 dst-address=0.0.0.0/0 gateway=\
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=yes port=8728
set winbox address="" disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no \
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password="" read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=\
15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/ipv6 nd
set [ find default=yes ] advertise-dns=no advertise-mac-address=yes disabled=no \
hop-limit=unspecified interface=all managed-address-configuration=no mtu=\
unspecified other-configuration=no ra-delay=3s ra-interval=3m20s-10m \
ra-lifetime=30m reachable-time=unspecified retransmit-interval=unspecified
/ipv6 nd prefix default
set autonomous=yes preferred-lifetime=1w valid-lifetime=4w2d
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=yes
/queue interface
set wlan1 queue=ethernet-default
set wlan2 queue=ethernet-default
set wlan3 queue=ethernet-default
set wlan4 queue=ethernet-default
set wlan5 queue=ethernet-default
set wlan6 queue=ethernet-default
set wlan7 queue=ethernet-default
set wlan8 queue=ethernet-default
set wlan9 queue=ethernet-default
set lan queue=ethernet-default
/radius
add accounting-backup=no accounting-port=1813 address=192.168.2.1 \
authentication-port=1812 called-id="" disabled=no domain="" realm="" \
secret=admin service=hotspot timeout=300ms
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
multiplier=5
/routing igmp-proxy
set query-interval=2m5s query-response-interval=10s quick-leave=no
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
0.0.0.0 timeout=1m ttl=50
/routing pim
set switch-to-spt=yes switch-to-spt-bytes=0 switch-to-spt-interval=1m40s
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
redistribute-connected=no redistribute-ospf=no redistribute-static=no \
routing-table=main timeout-timer=3m update-timer=30s
/routing ripng
/snmp
set contact="" enabled=no engine-id="" location="" trap-generators="" \
trap-target="" trap-version=1
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
"jan/01/1970 00:00:00" time-zone=+00:00
/system console
set [ find port=serial0 ] channel=0 disabled=no port=serial0 term=vt102
set [ find vcno=1 ] channel=0 disabled=no term=linux
set [ find vcno=2 ] channel=0 disabled=no term=linux
set [ find vcno=3 ] channel=0 disabled=no term=linux
set [ find vcno=4 ] channel=0 disabled=no term=linux
set [ find vcno=5 ] channel=0 disabled=no term=linux
set [ find vcno=6 ] channel=0 disabled=no term=linux
set [ find vcno=7 ] channel=0 disabled=no term=linux
set [ find vcno=8 ] channel=0 disabled=no term=linux
/system console screen
set blank-interval=10min line-count=25
/system gps
set channel=0 enabled=no set-system-time=no
/system hardware
set multi-cpu=yes
/system health
set state-after-reboot=enabled
/system identity
set name=MikroTik
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set lan disabled=yes display-time=5s
set wlan9 disabled=yes display-time=5s
set wlan8 disabled=yes display-time=5s
set wlan7 disabled=yes display-time=5s
set wlan6 disabled=yes display-time=5s
set wlan5 disabled=yes display-time=5s
set wlan4 disabled=yes display-time=5s
set wlan3 disabled=yes display-time=5s
set wlan2 disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no mode=unicast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system ntp server
set broadcast=no broadcast-addresses="" enabled=no manycast=yes multicast=no
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set 5 cpu=auto
set 6 cpu=auto
set 7 cpu=auto
set 8 cpu=auto
set 9 cpu=auto
set 10 cpu=auto
/system resource irq rps
set wlan1 disabled=no
set wlan2 disabled=no
set wlan3 disabled=no
set wlan4 disabled=no
set wlan5 disabled=no
set wlan6 disabled=no
set wlan7 disabled=no
set wlan8 disabled=no
set wlan9 disabled=no
set lan disabled=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 starttls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-ip-address="" filter-ip-protocol="" \
filter-mac-address="" filter-mac-protocol="" filter-port="" filter-stream=\
yes interface=all memory-limit=100KiB memory-scroll=yes only-headers=no \
streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
use-radius=no
[admin@MikroTik] >
