Hi All,
I configured hotspot & webproxy after that when i login from client computer, i am able to ping any website but i can’t browse internet.
class b 172.16.0.0/22, pc configuration, 1gb ddr2 ram, 80gb hdd,
Please help me to fix the problem.
Hi All,
It is the firewall nat problem. which port have you implemented the web proxy?
if it is the same as 80 you may have to change that with regards to dynamic hotspot rules which has been created in firewall nat
There is a small chance that you may have to create another nat rule and forward tcp 80 ports to the web-proxy port. make sure to prioritize that correctly in firewall nat section otherwise wont work.
keep us informed.
Sent from my SM-N910C using Tapatalk
