Configuring 2 GrooveA tie buildings together
Hi all,
I’m trying to get the best throughput between 2 GrooveA’s that are about 150-200ft apart. I currently have them functioning but the throughput is horrible. I’m getting about 8Mbps using BTtest between the 2. I currently am have them setup using WDS Dynamic. Here’s a graphic of the current setup.
Any suggestions would be greatly appreciated.
Thanks,
Ken
check signal levels, ccq %, nopise floor and possible interference
thats a ptp link
if you are using omni directional antenna that worse the problem because you are receiving noise and interference from all directions.
also you are generating interference in all directions
if you are using omni move to directional antennas that will improve a lot the situation
Directional antennas are a must if you want to improve your signal strenght.
That said, check your CCQ, the higher it gets, the better. Upgrade ROS to the latest stable version.
