configuring 7 port with the same vlan id on RB 201L-IN
Hi
Any one know how (and) if it is possible to configure RB 201 L-IN so that it will have 7 ports using the same VLAN - ID(access ports) and the eighth as a trunk port?
need it ASAP …
This is Mikrotik. You can set it up any way you like. :slight_smile: Go to interface add a vlan connected to each of the interfaces with the ID you want and port 8 just don’t add a Vlan interface attached to port.
