Configuring a network using two RB4011iGS+RM routers which need to communicate via IP radio (two parts)
I need to implement the configuration for a network which will involve using two RB4011iGS+RM routers. I am currently in the process of ‘bench testing’ with the routers connected directly by an Ethernet cable.
Why are you using a duplicate IP in the network?
192.168.100.1 appears on two different routers, sometimes on the same network segment..
What does “IP Radio” mean? Do they function as Layer 1? Layer 2? Or Layer 3?
From your diagram, VLANs don’t matter.. Are only access ports used?
