onubah
March 23, 2005, 11:54am
1
I can’t seem to figure out what is wrong in this configuration. I have my other PC connected to it through telnet and winbox. Bot I cant browse.
Below our my configurations:
/ip address add address=217.194.157.77/29 interface=ether1 disabled=no
/ip address add address=192.168.40.1/24 interface=ether1 disabled=no
/ip route add gateway=217.194.157.73
/ip firewall src-nat add out-interface=ether2 action=masquerade
/ip firewall dst-nat add action=nat protocol=tcp dst-address=217.194.157.77 to-dst-address=192.168.0.2
/ip firewall src-nat add src-address=192.168.40.0
Please feel free to spot out where the hole is or what is missing.
Paul
edzix
March 23, 2005, 1:00pm
2
IMHO 217.194.157.77/29 should be set on the ether2 interface.
Edgars
what does the dst-nat meant for ?
and the second source nat. pls examing them very well. if they have no real intention pls diable them
Eugene
March 24, 2005, 10:03am
5
AFAIK, IMHO means In My Humble Opinion
Next time use http://www.acronymfinder.com or http://www.dictionary.com
onubah
March 24, 2005, 12:04pm
6
Thanks guys.
Do you think that the Dst-nat or Src-nat could prevent the other computer on 192.168.40.1 from surfing the net?
Or if I set the 217.XXX.XXX.XX/29 to ether2 it enable it to surg?
djape
March 24, 2005, 3:06pm
7
Hi there, lafia or bauni
onubah:
Paul
remove /ip firewall dst-nat add action=nat protocol=tcp dst-address=217.194.157.77 to-dst-address=192.168.0.2
And forget src-nat and dst-nat as tools to forbidd somebody to use net.
You can acomplish something like that via input and forward rule.
Easiest way to do that is to bloc mac address…
Cheers…
P.S. How’s suya these days I miss that food a lot…
djape
March 24, 2005, 3:08pm
8
And always do Local traffic on one interface and Public traffic on another…
tonnie
March 24, 2005, 3:33pm
9
Like all others have hinted, all you need to be able to browse are the first three lines, followed by: /ip fire src-nat add out-interf=ether2 action=masque proto=all (for more free assistance in Nigeria, call Tony on 08023300004 or 08037264288)
P/S: the serbia guy should note that the suya is more interesting
Try This:
/ip address add address=217.194.157.77/29 interface=ether2 disabled=no
/ip firewall src-nat add src-address=192.168.40.0/24 out-interface=ether2 action=masquerade
REMOVE THE FOLLOWING
The first line I said to remove is /ip firewall dst-nat does not have a subnet 192.168.0.x associated with it. The default route is going to go back out and Masquerade traffic…Could be ugly unless you have another route added that pushes it down another route.
The second line /ip firewall src-nat… doesn’t do anything. No interfaces are specified, or no destinations are added.
This should all be in the documentation, or any IPTABLES documentation you see on the net.
onubah
March 25, 2005, 9:52am
11
Thats guys, you realy helped a lot.
I appreciate.
I am able to browse now. I will get back to you again.
Paul
