I need to configure my proxy to cache not only stuff accessed through web browsers, but also through the various auto-patches performed by other applications that doesn’t go through port 80 (http), say auto-patch for the anti virus, online games, etc. I have 80+ clients, and I don’t want my users to download the same thing everytime they want to patch the AV, or play games, or anything. Is this possible?
At the moment, this is what I have for my transparent proxy:
1 ;;; Proxy for Local LAN
chain=dstnat action=redirect to-ports=8080 in-interface=LOCAL dst-port=80 protocol=tcp
The way I see it, the “dst-port=80” part will only cache stuff that go through that port (http), right? (Sorry, mikrotik noob here). If I want to cache other stuff that are downloaded by other applications that doesn’t go through port 80, what should I add/change?
I’m thinking of adding lines like this one here, one for each port:
chain=dstnat action=redirect to-ports=8080 in-interface=LOCAL dst-port= protocol=tcp
So eventually I’ll have a bunch of lines that will do the proxy-ing (is that a word? ^_^) to port 8080 on the router.
Will it work?
peoxyy built in routeros only works with HTTP traffic and can only proxy that. all examples about port 80 is because, by default, all web (http) requests from your clients to servers goes to that port.
but if you want to use http server on different port, then yes, for transparent proxy you change that dst-port=80 to port you wish to use.
Regular proxy, eh? Ouch…
I’m gonna need some help here, you guys. Mikrotik noob alert.
Correct me if I’m wrong, but are these the steps that I need to do?
Remove the transparent proxy from the NAT rules.
Set the proxy address for EACH client using, say, IE’s internet options:
Change proxy IP to 192.168.1.1 port 8080
Check “Use same proxy for all protocols” (if there are any)
Do I need to set it for firefox as well? GAAAahhhh!!!
