Configuring a station
I am trying to configure a station that will connect to a Cisco access point. The MT will make a connection but was wondering if I could setup a transparent bridge using WDS just with one MT. Any assitance will be appreciated
WDS needs to be supported by both the station and Access Point.
Your cisco have to wds enable in configuration and accept interconnection with Your MT WDS.
I currently have a Mikrotik AP and I can get to my Wireless IP’s of 192.168.8.0/24 and the Ethernet (dhcp, File server etc) on 10.50.0.0/24 network. But my station can talk to anything as well but I can’t get a DHCP Server address from my 10.50.0.252 Windows 2003 server. Also I can’t ping my laptop which is directly connected to the ether1 interface with the Ip address of 10.50.0.80/24 using the Ping utility of the MT.
Any assistance will be appreciated.
Darren
please paste your ip address configuration in MT
here is my current config on the station
[admin@OhiowaStation] ip address> print
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.8.201/24 192.168.8.0 192.168.8.255 wlan1
1 10.50.0.228/24 10.50.0.0 10.50.0.255 wlan1
C - connect, S - static, r - rip, b - bgp, o - ospf
DST-ADDRESS PREF-SRC G GATEWAY DISTANCE INTERFACE
0 ADC 10.50.0.0/24 10.50.0.228 wlan1
1 ADC 192.168.8.0/24 192.168.8.201 wlan1
Currently no firewall rules
[admin@OhiowaStation] interface> wireless
[admin@OhiowaStation] interface wireless> print
0 R name="wlan1" mtu=1500 mac-address=00:15:6D:63:25:A3 arp=enabled
disable-running-check=no interface-type=Atheros AR5413
radio-name="00156D6325A3" mode=station ssid="MikroTik" area=""
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=2412 band=2.4ghz-b/g scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25
hide-ssid=no security-profile=default disconnect-timeout=3s
on-fail-retry-time=100ms hw-retries=15 preamble-mode=both
compression=no allow-sharedkey=no
