configuring cache from the beginning
dear all
i tried to configure cache but failed and lost.
i read the manual and did what asked also but no cache to work.
can anyone help plz.
all what i have is: ERROR
The requested URL could not be retrieved
here are my settings:
can anyone tell me where my mistake is plz.
10x again and waiting for your reply
  1. Enable “Transparent Proxy”
  2. Check the “in interface” it should be “LOCAL” not public…
    Regards
10x cibernet for your reply
the counter in the firewall - nat is counting now.
is there a way to know that the cache is really working?
10x again
Check the Webproxy Status…
ip webproxy monitor
‘Web-proxy test’ package provides even more useful information, ‘ip proxy connections print’ gives quite detailed input about current connections to the proxy.
Yes.. but have bugs… not for production…
hi
The filter in the Firewall – Nat that i made is counting and the browsing is working fine, but the status in the webproxy is NOT counting.
what does this mean? that the cache is not working?
10x again
Have you enabled proxy ?
I think you can paste proxy configuration export ‘ip web-proxy export’. However if you created correct NAT rule to redirect HTTP traffic to the proxy, web should not work in case of disabled/wrongly configured proxy.
hi friends
10x for the help , it is working very nice.
Maybe not the right topic, but, nevertheless :slight_smile: :
->> I installed 2.9.29 on my rb532 and I found out that some of the packages (I had perviously in 2.9.27) are missing, for example, there is NO web-proxy package… :question: :question:
Did I miss something while upgradeing or packages are, just, not … :open_mouth: finished !?
