Hello all,
I’m trying to configure a RB951Ui-2HnD (RouterOS 6.12 / Firmware 3.14) as an L2TP/IPSec client as follows:
VPN Server (non-MikroTIK) — Internet — Cable router ---- MikroTIK Router (L2TP/IPSec client)
In order to figure out the VPN parameters, I set up a Windows 7 PC as the VPN client as follows:
VPN Server (non-MikroTIK) — Internet — Cable router ---- Windows 7 PC
The VPN was successfully established with the following parameters:
- Enable LCP extensions
- Type fo VPN → Layer 2 Tunneling Protocol with IPsec (L2TP/IPSec)
- Authentication → Use preshared key for authentication
- Encryption → Require encryption (disconnect if server declines)
- Authentication → MS-CHAP v2
Once that was out of the way, I tried to configure the same parameters on the VPN client in MikroTIK. This is what I configured:
/interface l2tp-client
add add-default-route=no allow=mschap2 connect-to=<VPN_SERVER_IP> dial-on-demand=no disabled=no keepalive-timeout=60 max-mru=1450 max-mtu=1450 mrru=1600 name=\
L2TP_VPN password=<PASSWORD> profile=default user=<USERNAME>
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des pfs-group=none
/ip ipsec peer
add enc-algorithm=3des nat-traversal=yes secret=<PRESHARED_KEY>
Unfortunately that didn’t work. This is what the log file says:
may/10 22:45:04 l2tp,ppp,info L2TP_VPN: initializing...
may/10 22:45:04 l2tp,ppp,info L2TP_VPN: connecting...
may/10 22:45:06 l2tp,ppp,info L2TP_VPN: authenticated
may/10 22:45:06 l2tp,ppp,info L2TP_VPN: connected
may/10 22:46:11 l2tp,ppp,info L2TP_VPN: terminating... - session closed
may/10 22:46:11 l2tp,ppp,info L2TP_VPN: disconnected
may/10 22:46:11 l2tp,ppp,info L2TP_VPN: initializing...
may/10 22:46:11 l2tp,ppp,info L2TP_VPN: connecting...
may/10 22:46:13 l2tp,ppp,info L2TP_VPN: authenticated
may/10 22:46:13 l2tp,ppp,info L2TP_VPN: connected
may/10 22:47:18 l2tp,ppp,info L2TP_VPN: terminating... - session closed
may/10 22:47:18 l2tp,ppp,info L2TP_VPN: disconnected
Could someone give me a hand? I’m completely new to MikroTIK…
Thanks in advance!
