I have an RB1100AHx4, that I’ve “inherited”.
There’s some weird config with multiple brigdes in it, that I don’t want to break for now.
But there’s something I need to do - I have an internet connection with a /29 range assigned.
Currently, the everything goes through a 200.x.y.58 IP address, and there’s a 255.255.255.248 netmask assigned, with 200.x.y.57 gateway.
Now, I need to assign one of the IP addresses from my range (let’s say 200.x.y.59) to one of the devices in my network. I need this to be a direct connection - as in: I need this device to be “aware” of that address, so it has to be assigned directly. So port forwarding is not going to be an option. This is because there’s a service on this device, that logs all connections coming to it, and when I’ve used port forwarding, the service thought that all of the connections are coming from 192.168.10.1, instead of the public IP address of the actual source. Is it possible to achieve that?
If that helps, the router is currently running RouterOS 6.47.10, with license level 6.
Can someone, please, help? I’m completely lost when it comes to Mikrotik devices.
Depending on your current config the thing you want could be quite invasive.
But the best i could come up with is making a bridge and adding the interfaces that 200.x.y.57 and 200.x.y.59 are directly connected to.
Then add the IP 200.x.y.58/29 to the bridge.
Your new “WAN interface” will be the bridge (adjust your firewall accordingly) with default route to 200.x.y.57
Make sure traffic from src-addr 200.x.y.59 is not natted
