Configuring Routerboard for Datacenter use
So I have a 1/2 rack colocation at a datacenter that I just took over, all the servers have static public ip addresses and are plugged directly into a dumb switch (no mgmt or vlans) and so is the uplink, thus no security. I bought a RB2011UiAS-RM and a managed juniper switch to put in the rack.
Basically I have 7 IP subnets that I use in the rack, 4 /29, 2 /28, 1 /26.
I have created 7 vlans, 1 for each subnet, since each server gets 1 subnet.
VLANS - 200,210,220,230,240,250,260
Eth1- Uplink to Provider
Eth2- Uplink to Managed Switch Port 1
How do I setup the external ip’s on the vlans? Basically I need no firewall or nat, just so I can limit the speed of a certain server and make sure that 1 server on vlan xxx can only use its assigned subnet and the end user can not assign another subnet knocking another server offline, if that makes any sense.
I have port 1 on the switch tagged in all 7 vlans and ports 2,3,4,5,6,7,8 untagged in their specific vlans, now I just need to configure the router, any help would be appreciated. I already added all of my subnets in the addresses in the mikrotik. Thank You!
