Configuring the wlan1 onto a different subnet
I have a Mikrotik hAP lite
MY MOM USES TOO MUCH BANDWIDTH
so i want to use the QOS and Queues to limit her.
i have to put the wlan1 onto a different bridge in order to queue it without affecting th elan ports.
so i create a bridge called WIFI and i assign Wlan1 to it.
i then create a network 192.168.10.0/24 and i assign the network to a dhcp server with a new pool.
i recieve internet from my LTE router being 192.168.8.1
the lan to my pc is 192.168.9.1
i dont know if the wifi networks gateway must be 192.168.10.0 or 192.168.9.1 or 192.168.8.1
I created a dstnat in interface wlan1 and in bridge WIFI
when connecting to the wifi from my phone it says internet may not be available
mar/04/2020 16:10:58 by RouterOS 6.46.3
software id = JBB1-7STW
model = RB941-2nD
serial number = 9D740BE762C9
add name=WIFI
add admin-mac=C4:AD:34:18:40:59 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
country="south africa" default-forwarding=no disabled=no distance=indoors
frequency=auto installation=indoor mode=bridge ssid="It Hurts When IP"
wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=
UnicornRainbows wpa2-pre-shared-key=UnicornRainbows
add name=dhcp ranges=192.168.9.100-192.168.9.150
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp_pool1 disabled=no interface=WIFI name=dhcp1
/interface bridge nat
add action=accept chain=dstnat in-bridge=WIFI in-interface=wlan1
add bridge=bridge comment=defconf interface=pwr-line1
add bridge=WIFI comment=defconf interface=wlan1
add address=192.168.9.1/24 comment=defconf interface=ether2 network=192.168.9.0
add address=192.168.8.2/24 interface=ether1 network=192.168.8.0
add address=192.168.10.0/24 interface=wlan1 network=192.168.10.0
/ip dhcp-client
add address=192.168.9.0/24 comment=defconf gateway=192.168.9.1 netmask=24
add address=192.168.10.0/24 gateway=192.168.9.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.9.1 comment=defconf name=router.lan
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid" connection-state=
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed"
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=
out,none out-interface-list=WAN
add distance=1 gateway=192.168.8.1
/system clock
set time-zone-name=Africa/Johannesburg
/tool mac-server
/tool mac-server mac-winbox
please assist
First, please put config exports into code blocks, makes it much easier to read.
For your problem, this should fix it:
## make sure your dhcp sends out dns servers and correct gateways. A Gateway must be in the same subnet to be reachable.
add address=192.168.10.0/24 gateway=192.168.10.1 dns-server=192.168.10.1
## change this
## to this:
add address=192.168.10.1/24 interface=WIFI network=192.168.10.0
-Chris
Sorry i will put code into code blocks next time
also i did what you suggested and it still doesnt work :frowning:
# mar/05/2020 15:18:57 by RouterOS 6.46.3
# software id = JBB1-7STW
# model = RB941-2nD
# serial number = 9D740BE762C9
add name=WIFI
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country="south africa" default-forwarding=no disabled=no distance=indoors \
    frequency=auto installation=indoor mode=bridge ssid="It Hurts When IP" \
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=\
/ip dhcp-client
add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8,192.168.10.1
/ip dns static
    invalid
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
/system clock
/tool mac-server
Hey man,
192.168.10.0 can’t be used, I won’t extend myself on this but you can google some network subneting if you want to know more about it
So change it to
add address=192.168.10.1/24 interface=wlan1 network=192.168.10.0
Then the gateway for that network should be also that IP address 192.168.10.1
