I finally managed to upgrade routerOS version 6.23 and firmware 3.18 on both RB.
After reset-configuration, this is the content of file configuracion saved with >export file=name of bridge:
jan/02/1970 00:56:19 by RouterOS 6.23
software id = BWUT-JBLI
add name=wds-bridge
/interface wireless
set [ find default-name=wlan1 ] disabled=no l2mtu=2290 mode=bridge ssid=
MikroTik wds-default-bridge=wds-bridge wds-mode=dynamic
/port
set 0 name=serial0
add bridge=wds-bridge interface=ether1
set enabled=no
add address=192.168.1.250/24 interface=ether1 network=192.168.1.0
/system identity
set name=bridge
And this is print information for bridge:
[admin@bridge] > interface wireless print
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:26:A1:54 arp=enabled interface-type=Atheros AR5413 mode=bridge ssid="MikroTik" frequency=5180 band=5ghz-a
channel-width=20mhz scan-list=default wireless-protocol=any antenna-mode=ant-a wds-mode=dynamic wds-default-bridge=wds-bridge wds-ignore-ssid=no bridge-mode=enabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default compression=no
[admin@bridge] > interface bridge print
0 R name="wds-bridge" mtu=auto actual-mtu=1500 l2mtu=1526 arp=enabled mac-address=00:0C:42:13:B5:11 protocol-mode=rstp priority=0x8000 auto-mac=yes
admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
[admin@bridge] > interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 ether1 wds-bridge 0x80 10 none
1 D wds1 wds-bridge 0x80 74 none
[admin@bridge] > ip address print
ADDRESS NETWORK INTERFACE
0 192.168.1.250/24 192.168.1.0 ether1
[admin@bridge] > interface wireless wds print
Flags: X - disabled, R - running, D - dynamic
0 RD name="wds1" mtu=1500 l2mtu=2290 mac-address=00:0C:42:26:A1:54 arp=enabled master-interface=wlan1 wds-address=00:0C:42:26:A1:62
And after reset-configuration, this is the content of file configuracion saved with >export file=name of station-wds:
jan/02/1970 00:36:01 by RouterOS 6.23
software id = CVWN-K2AG
add name=wds-bridge
/interface wireless
set [ find default-name=wlan1 ] disabled=no l2mtu=2290 mode=station-wds
/port
set 0 name=serial0
add bridge=wds-bridge interface=wlan1
set enabled=no
add address=192.168.1.251/24 interface=ether1 network=192.168.1.0
And this is print information for station-wds:
[admin@station-wds] > interface wireless print
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:26:A1:62 arp=enabled interface-type=Atheros AR5413 mode=station-wds ssid="MikroTik" frequency=5180 band=5ghz-a
bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
[admin@station-wds] > interface bridge print
0 R name="wds-bridge" mtu=auto actual-mtu=1500 l2mtu=1526 arp=enabled mac-address=00:0C:42:26:A1:62 protocol-mode=rstp priority=0x8000 auto-mac=yes
[admin@station-wds] > interface bridge port print
0 wlan1 wds-bridge 0x80 10 none
1 ether1 wds-bridge 0x80 10 none
[admin@station-wds] > ip address print
0 192.168.1.251/24 192.168.1.0 ether1
With connection I said in my first post, I´m not able to ping from PC1 (192.168.1.10) to PC2(192.68.1.11) nor from PC2 to PC1
I´m able to ping from PC2 to PC1 if I connect PC1 and bridge station to my adsl-router with IP:192.168.1.1 and set gateway to 192.168.1.1 to bridge and wds station.
For give you more information, from terminal inside bridge, it is not able to ping to 192.168.1.10 nor wds station to 192.168.1.11.
Thanks for your support.
