Hi there
My RB532 says this;
system routerboard print
routerboard: yes
model: “532A”
serial-number: “16C901D3FA87”
current-firmware: “2.10”
upgrade-firmware: “2.12”
But I see that this firmware is available;
http://www.routerboard.com/files/rb-2.15/adm5120-2.15.fwf
Can I use this for the 532?
Thanks.
Hai Fren,
No, your routerOS need 2.12 version, and it’s available now on RouterOS,
Just follow like this with CLI command
/syst rout print
/syst rout upgr
and select Y , than please reboot your router quickly.
/syst rebo
select Y
after reboot check your new firmware installed, … good luck
hilton:
Hi there
My RB532 says this;
routerboard: yes
model: “532A”
Thanks.
your’s shows 2.12 because you don’t have latest RouterOS installed. when you install RouterOS 3.9 along with the RouterBOARD package, it will show you latest firmware available.
Apart from that - balimore is right, just upgrade.
Thanks balimore and normis.
normis:
i upgrade it to 2.15, now the routerboad stop working unless i reset it !!! help
