I will be receiving my Mikrotik router this evening. I was thinking I could use QuickSet to do most of the setup, and then change/add the settings I need for what QuickSet doesn’t cover. However, the manual has the following:
How is Quickset different from the Webfig tab, where a whole bunch of new menus appear?
If you need more options, do not use any Quickset settings at all, click on “Webfig” to open the advanced configuration interface. The full functionality is unlocked.Can I use Quickset and Webfig together?
While settings that are not conflicting can be configured this way, it is not recommended to mix up these menus. If you are going to use Quickset, use only Quickset and vice versa.
Am I really not supposed to use QuickSet at all if I plan to make changes after using QuickSet? I understand I don’t want to use QuickSet anymore after making my custom changes, but I’d be surprised if I at least can’t use it for the initial setup.
