I eliminate the bridge-local
I change DHCP server so it is attached to Port 2
I change port 3 so that it isn’t a slave (master = none).
I add a DHCP server to Port 3.
Port 2 works, Port 3 doesn’t… after some undetermined amount of time, the DHCP server for 3 is flagged “invalid”, though this doesn’t happen right away. Once it is flagged, I can’t get it to be valid and nothing explains what the problem is.
I thought perhaps it needs its own exclusive pool, so I tried that but it doesn’t help.
I may very well be going about this all wrong, I’m not sure. I’m completely new to RouterOS.
Ultimately I want the 4 gigabit ports and one fast port to be on their own so I can better control them (queues, etc) and then ports 7-10 can be master/slaved up (or not).
OK, thanks… but then am I not going to run into trouble queuing later? I’m sure I read in multiple places that you have less control over bridged ports, and that makes sense.
I know I’m missing some basic understanding here. Something’s gotta click soon.
