Connect 2 different network with RB750GR3
I’m new and a beginner on network.
I have a mirkotic RB750GR3 and I would like to connect 2 different network (for test to simulate a router)
On eth1 I connect a device with 10.1.8.3/18 and Gateway 10.1.8.1
On eth2 I connect a device with 172.20.43.60/24 and Gateway 172.20.43.1
How I can connect the two different network on eth1 and eth2 on my Mirkotik ?
What is the correct methods? Is this a bridge or a router roule?
Hi there,
just go in winbox to “IP-> Addresses” and give eth1 and eth2 an ip address in the specific lan.
when there are no firewall rules you dont need to do anything else. It just works, because a router routes!
Go to “IP->Routes” and there you will find dynamically builded routes to each subnet (DAC in first column - dynamically, active, connected).
The 2 LANs are not separated when there are no firewall rules.
when you are on device 172.20.43.60/24 you can reach device 10.1.8.3/18.
But you cannot use ip-broadcasting or anything like that because the devices are still in different subnets - they cant find each other with auto-detection functions in windows etc (via IP).
A bridge only makes sense, when eth1 and eth2 are in the same subnet.
Two directly connected routers know each other…!
