Connect 2 MT Router
Dear all,
I read Thsi topic
my configration:
First MT to client
[sami@To client] /ip address> print
ADDRESS NETWORK BROADCAST INTERFACE
0 15.15.15.1/24 15.15.15.0 15.15.15.255 ether1
1 10.2.0.22/24 10.2.0.0 10.2.0.255 ether1
2 192.32.31.1/24 192.32.31.0 192.32.31.255 ether2
[sami@To client] /ip firewall nat> print
[/b]
 0   chain=dstnat action=redirect to-ports=8080 protocol=tcp
     src-address=192.32.31.0/24 dst-address=!10.2.0.4 in-interface=ether2
 1   chain=srcnat action=masquerade
[sami@To client] /ip proxy> print
          enabled: yes
             src-address: 0.0.0.0
                    port: 8080
            parent-proxy: 10.2.0.4
       parent-proxy-port: 8080
     cache-administrator: "webmaster"
          max-cache-size: none
           cache-on-disk: no
  max-client-connections: 600
  max-server-connections: 600
          max-fresh-time: 3d
   serialize-connections: no
       always-from-cache: no
          cache-hit-dscp: 4
             cache-drive: system
[sami@To client] /ip proxy access> print
Flags: X - disabled
#   DST-PORT             DST-HOST        PATH        METHOD  ACTION HITS
 0   !433                                             CONNECT deny   0
 1   ;;; Our Customers
                                                              allow  0
 2   ;;; Deny using us as telnet ans SNMP relay
     23-25                                                    deny   0
 3   ;;; Deny everything else
                                                              deny   0
[b]Second MT For Cashe:
[/b]
[sami@Ca] ip address> print
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   12.1.0.1/32        12.1.0.1        12.1.0.1        Real
 1   10.1.0.23/24       10.1.0.0        10.1.0.255      Real
 2   10.2.0.254/24      10.2.0.0        10.2.0.255      Fake
[sami@Ca] ip firewall nat> print
 0   chain=srcnat action=masquerade
[sami@Ca] > ip web-proxy print
         enabled: yes
                    port: 8080
                hostname: "10.2.0.2"
       transparent-proxy: no
            parent-proxy: 0.0.0.0:0
         max-object-size: 200000KiB
             cache-drive: system
          max-cache-size: unlimited
      max-ram-cache-size: unlimited
                  status: running
      reserved-for-cache: 56876032KiB
  reserved-for-ram-cache: 2048KiB
[sami@Ca] > ip web-proxy access print
0   ;;; allow CONNECT only to SSL ports 443
     dst-port=!433 method=connect action=deny
 1   src-address=192.32.31.0/24 action=allow
 2   action=deny
When i connect user using pppoe there is internet but web-proxy not working plz correct my code
thxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
sory this topic :http://forum.mikrotik.com/t/cache-all-http-downloads/2764/1
plzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
