Connect 2 sfp+ ports through software
I have the CRS305-1G-4S+IN switch. All I need to know is how to configure this with the router OS so that , the ethernet packets from sfp+ port 2 is routed to sfp+ port1 and vice versa (Full duplex). And also need to know if this sfp+ supports 10GBps
Do you mean literal routing, or are you using the term loosely to mean the packets should somehow get from one port to another and never mind exactly how? I ask because proper routing won’t run at 10 Gbps on this switch, being a switch and not a 10G class router.
That said, the default switching configuration should do 10 Gbps all day long between those two ports.
Technically, no, because the capital B makes it 10 Gbyte/sec, 80 Gbit/sec.
Assuming what you meant was “10 Gbps,” with a lowercase b for bits instead of bytes, I believe it suffices to quote the top-line spec on the product page: “…and four SFP+ 10Gbps ports.”
