i have a CCR1009-7G-1C-1Splus and i have a sfp+ uplink and i need a sfp+ uplink for my switch , do you have any idea how can i connect 2 sfp+ to CCR1009-7G-1C-1Splus without swap it with other brands?
thanks
Unfortunately the answer is in the subject. The designation of the product as 1Splus means it has 1-SFP-plus port. The “1C” (combo) port is either RJ45 or SFP - i.e. will only work at 1Gbit/sec. You’ll need a 2S+ router if you want 10G uplink and a separate 10G connection to a switch.
But of course you can swap it with CCR1036-8G-2S+ (same brand)!
Or when your uplink is less than 1 Gbps you can live with using SFP (1 Gbit/s) to either the switch or to the uplink.
