connect 40 km with 30 MB bandwith
Dear,
sir i am a claint of mikrotik, can it support 40 Km with bandwidth 30 MB. IS it possible through Nstrem2, because i am the network engineer , that`s why i tell you.SIR PLEASE TELL ME IT CAN SOLVE BY NSTREM2 OR NOT or there is another solution.If some other then tell me
sir it is urgent.
Do you need 30Mb full duplex or half? and yes you can do this with Nstream 2
Regards
Sir,
it can be done with 2m dishes and nstreme2.
Any other solution will cost you a fortune.
Cheers :wink:
Half duplex mode is it support
I have a connection of 45 KM nstreme dual 5,2 GHZ , bandwidth 36 MBPS
dishes 28 dbi ,
