Connect as station with username/password
Today I failed in setting up an rb951g for a customer. I thought it would be a simple case, but I couldn’t solve it.
The case is that this customer (small company) has moved into a building where they have internet access from the owner of the building, provided as wlan only. My plan was to set an rb951g as router, using the wlan in station mode for wan access. The problem was that this wlan required username and password. I suppose it is using WPA2-EAP with radius authentication.
I’ve done this several times using a pre shared key. How do I solve this when the wlan uses radius? Where in the rb-config do I enter username and password?
I seem to recall this being a feature request here recently. Apparently there is no dot1x supplicant on the Mikrotik which would be necessary to do EAP/PEAP authentication.
I could be wrong though…
Oh, so it’s not just me being blind this time?
Did you try this?
I didn’t have the username and password fields in that menu. Guess I need a software upgrade. Which ROS version is that screen shot from?
6.37 and up
