Hello
I’m using RB 411U
all I have done is this
Wlan IP: 10.0.0.254/24 - config as AP 802.11 20Mhz - simple WiFi configuration
Ehter1 IP: 192.168.1.254/24
now I have connected:
1.Computer A - connect to the LAN address - 192.168.1.10/24
2.Computer B - connect to the Wlan with address - 10.0.0.10/24
I want to be able to make the 2 computers “talk”
what I need to do more?
add rules in the firewall?
Thanks ,
If the RB411U is the default gateway for both devices you shouldn’t need to do anything, it should route between them unless you have any firewall rules to prevent it.
can you show me what I need to do in the firewall nat?
which rules to add?
I have found this WiKi http://wiki.mikrotik.com/wiki/NAT_Tutorial
and try to do as told , but still doesn’t work
I don’t have ping between computer connected to Wlan and computer connected to Ether1
also I don’t have ping from computer connected on Ether1 to 192.168.1.1
I’m pretty sure this is en easy and stupid question - so I will happy to know this
I have found my problem
my computer was connected to an external switch and firewall - this why I didn’t able to “talk” this 2 networks\computer.
after I have connected the computer just to the router it works
