Hello
I would like to ask you if I can connect APs with OS 6.49.18 to the Router with OS 7.18.2 so that they download their configuration? (like capsMAN)
The thing is that I only have Provisioning on the router and I have CapsMAN on the AP.
Maybe you can give me some direction
I tried to set it up with chatgpt but this chat is a disaster
That sounds like the old CAPsMAN version…the router should have wireless driver installed (can be found in the extra package) and then you are good to go:
https://wiki.mikrotik.com/Manual:CAPsMAN
But I can “understand” ChatGPT…your question is hard to understand:
Yes you can!
What configuration?
CAPsMAN pushes config.
Put it on the router!
