connect/disconnect problem
hi there!
i have a problem with short distance link, both sites Atheros 5212 rev. 1. Connect-disconnect appears into the log of station box (see below log fragment). Bridge box log contains nothing at the same time.
Actually link is not down, there is connection with maximum bandwith at the same time. The problem is only large ping times.
Boxes are the same: Cel-D 2600MHz 128MB of RAM, 128MB HDD flash, Atheros 5212 rev. 1. Licensed ROS level 4 and level 5.
The usual amount of traffic is 1/10 from the bandwith test shown.
=========LOG FRAGMENT=============
jan/13/2006 21:21:16 wlan1: 00:0B:6B:36:B8:66 disconnected
jan/13/2006 21:21:17 wlan1: 00:0B:6B:36:B8:66 connected
jan/13/2006 22:37:29 wlan1: 00:0B:6B:36:B8:66 disconnected
jan/13/2006 22:37:31 wlan1: 00:0B:6B:36:B8:66 connected
jan/13/2006 23:01:46 wlan1: 00:0B:6B:36:B8:66 disconnected
jan/13/2006 23:01:48 wlan1: 00:0B:6B:36:B8:66 connected
jan/14/2006 00:27:44 wlan1: 00:0B:6B:36:B8:66 disconnected
jan/14/2006 00:27:46 wlan1: 00:0B:6B:36:B8:66 connected
so, any ideas?
thank you.
Can we have an idea of your ping reply time?
Uche
tipically 0.6ms, with problems - 100ms. too much
