Dear all,
I've built a home network and need help, because I'm very hard fighting against a Mikrotik router in my home. I have a little experience of networking, but for routing I am beginner. My setup is as follows:
Internet
I
Modem/Router with integrated switch provided by ISP, located in living room
IP (valid for LAN, Gateway, DNS-Server): 10.0.0.138
I
I-- PC1 (Win10, living room, streaming, Internet surfing etc.), IP: 10.0.0.10
I-- PC2 (Win10, another room, same use as PC1), IP: 10.0.0.20
I
WAN on Ethport 1 of Router Mikrotik RB3011, located in work room, IP: 10.0.0.1
Bridge to private LAN, IP: 192.168.88.1
I
I-- NAS (work room, Supermicro with Xeon-CPU, OpenMediavault), IP: 192.168.88.10
I-- PC3 (working with documents, CAD, photoeditor), IP: 192.168.88.20
The reason for this wiring is to connect PC1 and 2 in "DMZ" as direct as possible to Internet, no bottleneck should be between.
Devices in private LAN have access to internet and are not visible in DMZ and are administrated in private LAN, this works without problems. NOw I want to have ONLY LOCAL access from my devices in DMZ to shares of NAS or PC3 in LAN. Internet is not needed. How can I solve it?
With NAT and SMB I am restricted to port 445 on router and can only access one device in LAN, FTP needs a client like FileZilla on my PCs in DMZ, both ways are also unsecure.
Concerning IPv6, I can find out local IP's of all NICS, but how to connect them is for me alchemy.
Now I' trying VPN with WireGuard and have many questions:
- Is it possible to set up a VPN-tunnel from DMZ to LAN? For my understanding, it's the same like access via Internet.
- My router has possibility of WireGuard. Can I use WireGuard without Internet connection?
- Is it possible to set up my router as WireGuard-server and build a tunnel from PC to router?
- Do I need to install WireGuard client only on PC's in DMZ or also on devices in LAN?
- And if all previous is possible, could somebody give me a small example, how to set up the router, e.g. connect PC1 to NAS?
I've seen many tutorials and more or less good videos in Internet, but nothing what matches my needs.
Any help would be very appreciated!
