Connect Groove 52HPn as wifi client to RB951Ui-2HnD
Hi, I bought 7 pieces Groove 52HPn(level 3) and I want to connect as wifi clients to RB951Ui-2HnD(level 4).
I try several ways: Groove 52HPn like bridge or like a router, CPE or PTP bridge…
Maybe It is not possible(distance is 200m)? Groove 52HPn blocks and disconnect me from winbox and I cannot generate autosupout.rif file.
When I connect Groove 52HPn to RB2011Uas(level 5) or to linksys 54gl all works fine.
Temporarily I placed another RB951Ui-2HnD(level 4) in bridge mode.
Is there a way for Groove 52HPn(level 3) to work as wifi client to RB951Ui-2HnD(level 4)?
I forgot to say that I use N-male adapter and small antenna
are you using all with omni-directional antennas??
YES
If you take a Groove 52Hpn and an RB951ui-2Hnd and set them to factory defaults then change the subnet on one or the other, the Groove will have no problem connecting to the RB951ui.
At 200m it is possible that your antenna is not adequate. What signal strength does the Groove see from the RB951ui?
