Connect HAP AC via using CAPMAN, can not ping/access devices when connected to wifi
Hi.. Newbie here.
I have HEX S (RB760iGS)as main router and DHCP server. For wifi AP, i am using CAP Lite and HAP AC LITE (RB952Ui-5ac2nD).
everthing working fine, except when i am connecting my wifi printer via wifi HAP AC lite. the printer can only be access from the computer that connected through wifi CAP lite. when the computer connected via WIFI through HAP AC, the computer can not connect to wifi printer. i can not ping the printer wifi.
btw, i am setup the wifi via CAPMAN. the setting for CAP lite and HAP AC lite is similar (at CAPMAN), but it behave differently. do not know why. Also, to set capman slave at hap ac, i did it via reset button.
Why i can not connect to my printer when the computer connected to hap ac wifi? interesting enough, when i connect the computer via hap ac ethernet (cable), it can print. So i believe there is something wrong with wifi forwarding setting at hap ac, but since i connected via capman, i am not sure what to set.
I am attaching my hexs and hap config bellow.
hex-hide.rsc (4.79 KB)
hapac-hide.cfg.rsc (1.24 KB)
In capsman configuration enable “client to client forwarding” inside the datapath tab…
