Connect MikroTik CRS504-4XQ-IN 100Gb switch with TPLink 1Gb switch.
I’m trying to connect my new MikroTik CRS504-4XQ-IN 100Gb switch with my TPLink 1Gb switch.
Therefore I use a S+RJ10 SFP Plug with a QSFP to SFP Adapter and then a RJ45/Cat5 cable to connect both switches.
Is this the proper way to go?
Will the switch automatically detect the uplink?
I tried to set/force the interface speed to 1Gb.
The interface ist listed up and running. Some bytes traffic are shown, but at the end the switches are not conntected.
When I connect the 100Mb management port with a RJ45/Cat5 cable to the switch, then the switches are connected/uplinked.
Do you have any advice here?
