Connect Mikrotik Groove to Beacon Wifi
I know this is a long shot, but I thought I would give it a try. I have a Mikrotik Groove on my boat and I am trying to connect to the marina’s wifi system which is provided by a company called Beacon Wifi. It is an open network and then the first web page redirects you to their log on screen. It works fine when I connect direct to my computer. And I have a friend down the dock that is connected with a Ubiquiti Bullet. Beacon tech support says they are not blocking anything. They can see my Groove’s mac address connect to their AP. But I can’t pass data to their network. I tried a static IP in case it was a DHCP problem but no luck. The log says:
failed to connect, on 2437000, association timeout
I have been working with the log trying to find the problem. I did find that it did not like the nstream so I changed that to 802.11. But still no connection.
The quick connect window just says “searching for network” after I select the AP and connect.
Anyone got any ideas?
