Connect MikroTik to Netgear VPN
Is any one aware of any examples or Wiki on how to establish a VPN connection between a Mikrotik box and a Netgear Prosafe VPN router?
Thank you
As far as I understand, Netgear Prosafe uses IPsec:
http://kbserver.netgear.com/pdf/vpn_client2fvs.pdf
RouterOS manual for IPsec:
http://wiki.mikrotik.com/wiki/Manual:IP/IPsec
Yes Netgear uses IPSEC however the Mikrotik documentation is useless in the situation
I was wondering of anyone has ever successfully connected top a Netgear IPSEC VPN
An IPSec tunnel is an IPSec tunnel, it is a standard. You need to look at the Netgear documentation and the MikroTik documentation and see how the have implemented the various options and features and make the necessary adjustments on both ends.
