The way i usually connect to another AP is via station mode and entering the SSID. But is there anyway to tell the MT device to connect to any SSID.
I ask bc i would like to setup a box that would connect to any SSID and then run DHCP client on that WAN int and a dhcp server on the LAN int and then be able to plug in my device. Or i could always do the same but just bridge the two port.
they key here is that the device does not have to be told what SSID to connect to.
tks
