Connect to Camera in Hotspot from Management Network
Hello Guys.
I have some Network Cameras in a Hotspot Environment.
I need to access to these cameras from my Management Network
Hotspot 172.16.0.0/24
Managment 10.100.124.0/23
But some dymnamic firewall rules from the Hotspot Router block my traffic.
What i need to do, to bypass them.
Ip binnindgs does not work.
Thanks.
Matthias
Why don’t you make a separate SSID+VLAN for your cameras, outside of the hotspot network?
I already have an extra vlan for this hotspot system.
Vlan20
I think in have a solution. I disabled dst nat and it already worked
Put a filter forwarding rule to allow connections from the MAIN network to the HotSpot Network above the drop rule?
