Hello.
I am new to Mikrotik so please do not burn me to much. ![]()
I have a problem with connection to a LAN that is behind a Mikrotik router.
The connetion works betwen our HQ and the dislocated Mikrotik network over IpSec.
Example 1:
HQ(192.168.10.0/24)<==ipsec==>Mikrotik LAN(192.168.80.0/24)
- This layout works.
It does not work between a another dislocated unit and the Mikrotik network.
Example 2:
Dislocated unit(192.168.9.0/24) <==ipsec==> HQ(192.168.10.0/24) <==ipsec==> Mikrotik LAN(192.168.80.0/24)
- This does not work. I cannot get a connection from 192.168.9.0/24 to 192.168.80.0/24.
-We have other layouts with the exact same layout but it does not use Mikrotik and it works.
Mikrotik firewall configuration:
[admin@MikroTik] >>ip firewall filter print
0 chain=input action=accept protocol=ipsec-esp log=no log-prefix=""
1 chain=input action=accept protocol=udp port=500 log=no log-prefix=""
2 chain=input action=accept protocol=udp dst-port=1701,500,4500 log=no log-prefix=""
3 chain=input action=accept protocol=tcp log=no log-prefix=""
4 chain=output action=accept out-interface-list=all log=no log-prefix=""
5 chain=input action=accept log=no log-prefix=""
6 chain=forward action=accept log=no log-prefix=""
[admin@MikroTik] >> ip firewall nat print
0 chain=srcnat action=masquerade log=no log-prefix=""
1 chain=srcnat action=accept out-interface=lte1 log=no log-prefix=""
2 chain=srcnat action=accept log=no log-prefix=""
3 chain=srcnat action=accept src-address=192.168.80.0/24 dst-address=192.168.10.0/24 log=no log-prefix=""
4 X chain=srcnat action=accept src-address=10.212.134.0/24 dst-address=192.168.80.0/24 log=no log-prefix=""
5 chain=srcnat action=accept src-address=192.168.10.0/24 dst-address=192.168.80.0/24 log=no log-prefix=""
Mikrotik IPsec configuratin:
[admin@MikroTik] >> ip ipsec policy print
Flags: T - template, X - disabled, D - dynamic, I - invalid, A - active, * - default
0 TX* group=default src-address=::/0 dst-address=::/0 protocol=all proposal=default template=yes
1 A src-address=192.168.80.0/24 src-port=any dst-address=192.168.10.0/24 dst-port=any protocol=all action=encrypt level=require
ipsec-protocols=esp tunnel=yes sa-src-address=222.222.222.222 sa-dst-address=111.111.111.111 proposal=proposal1 priority=0
ph2-count=1
[admin@MikroTik] >> ip ipsec peer print
Flags: X - disabled, D - dynamic, R - responder
0 address=111.111.111.111/32 auth-method=pre-shared-key secret="SomeRandonPSK" generate-policy=no policy-template-group=default
exchange-mode=main send-initial-contact=no nat-traversal=yes proposal-check=claim hash-algorithm=sha1 enc-algorithm=3des
dh-group=modp1024 lifetime=1d dpd-interval=2m dpd-maximum-failures=5
[admin@MikroTik] >> ip ipsec proposal print
Flags: X - disabled, * - default
0 X* name="default" auth-algorithms=sha512 enc-algorithms=aes-192-cbc,des lifetime=1h pfs-group=modp1024
1 name="proposal1" auth-algorithms=sha1 enc-algorithms=3des lifetime=1h pfs-group=none
Any help would be apreciated.
Best regards
