Device: CRS125-24G-1S-2HnD
I installed capsman on this device.
Is it possible to use the local wifi of this device to connect to the capsman installed on the same device.
So i can control all my wifi devices, also from the same device, with capsman.
My connection to the capsman is dropped every x seconds.
I see every x seconds new interfaces with new names.
solved:
changed capsman address to: 127.0.0.1
accepted input firewall rule for udp port 5246 and 5247.
