Connect to the Ap
I have a RB750 Router and I have an Ubiquiti AP connected to it.
How can I configure the firewall to connect to the AP from an external IP?
Thanks for your time.
If you are using IPv4 with NAT/Masquerade, you should add a [dst-nat] rule to your firewall’s NAT chain (the NAT tab in the IP->Firewall sub-menu). Set the Dst-Address to the IP address of the network that doesn’t have direct access to the AP (most likely your public IP address) and set the [Action] to [dst-nat].
Configure any other settings as you see fit (for instance, port number(s), prototol, In-/Out-Interface, Src-Address/Src-Address-List)
Hi Lenart,
I configured the NAT as you said and it did not work.
This is what I did.
Are you accepting the final target port in the forward chain? I guess you are dropping it by firewall.
