Connect to the container without exposing the port
Hi everyone, I really need your expert Mikrotik knowledge :smiley:
My setup: a remote server in the cloud, running wstunnel and WireGuard. General idea is if a client is in restricted network and cannot connect to WG directly, they go through wstunnel which wraps WireGuard into a Websockets tunnel. I have tested it locally and it works, so server settings are out of question.
I’m starting wstunnel like this:
wstunnel -L ā€˜udp://12345:0.0.0.0:127.0.0.1:51820’ …., which basically means: ā€œlisten on all interfaces locally for port 12345, and on the other side of the tunnel, forward it to 127.0.0.1 port 51820ā€. This works on both rpi4 and my laptop, I can ping server’s WG IP no problem. So far so good.
The real fun starts when I put wstunnel in the container and try to run it on the router (hAP ax2). Following wstunnel configuration logic, on my hAP WG peer should have WG endpoint configured as
[container IP ]:12345,
so wstunnel can pick up this connection and forward it upstream. The problem is it doesn’t work :smiley: in my container logs, I can see a connection to the server being made, and on the server wstunnel logs also report that connection is established, BUT:
  • I cannot ping MikroTik peer;
  • MikroTik’s logs say that WG handshake didn’t succeed (and interface status and counters also indicate that).
Now, if I go into the container shell and install wg-quick there, put some pubkey and addr and add it on the server, I can ping the server from inside the container and vice versa, so wstunnel IS working. The problem lies somewhere with forwarding packets back from the container to the router.
I’m using standard ā€œBridge with NATā€ container configuration from the official manual:
/interface/veth/add name=veth1 address=172.17.0.2/24 gateway=172.17.0.1
/interface/bridge/add name=containers
/ip/address/add address=172.17.0.1/24 interface=containers
/interface/bridge/port add bridge=containers interface=veth1
Manual also mentions these two NAT rules, which I tried both with no luck:
add chain=srcnat action=masquerade src-address=172.17.0.0/24
add action=dst-nat chain=dstnat dst-address=192.168.88.1 dst-port=80 protocol=tcp to-addresses=172.17.0.2 to-ports=80
I’m also not sure they’re really needed, since:
  1. masquerade rule was not being hit (or I missed something), and
  2. I probably can adjust 2nd rule to use port 51820 and put 192.168.88.1 into my WG endpoint config, but this loop feels wrong, and also exposes wstunnel to my LAN, which I don’t want.
My Mikrotik WG peer configuration is
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=172.17.0.2 endpoint-port=51820 \
    interface=wg1 name=wstunnel public-key="mykey"
I’m out of any ideas, if anyone can suggest anything I’m all ears.
Thanks a lot!
Of course I was stupid and messed my WireGuard keys :laughing: :laughing: :laughing:
I had to put container in the default bridge though, I’m thinking of adding a firewall rule to limit access from anyone != 192.168.88.1.
