Hi, I have an l2tp server on my mikrotik RB4011iGS set up, I can connect to this via vpn from outside my network without any problems in the past. But recently my ISP put me under cgnat and now I can’t connect to my server from outside my network. I have also set up and working ipv6 connection verified on https://test-ipv6.com. Can I connect to ipv6 instead of my usual ipv4 using vpn that’s already set up on my router? if so is there any additional set up that I need? I’m pretty new on networking in general and would appreciate any help thanks.
It is possible to configure an IPv6 address for an L2TP client on RouterOS 7, but not on RouterOS 6 (just tested on 7.3 and 6.47.10). So I suppose you can run an L2TP server on 7.x too. However, there’s a fix on some L2TP related issue which has still not been released, so I’d be careful at the moment.
If you don’t want to upgrade to ROS 7, IKEv2 should work on IPv6 in ROS6. The question is what are your VPN client devices. Moving the L2TP server to a virtual CHR in a datacenter and let the 4011 connect to that CHR too may be yet another solution.
Thanks for the reply. I’m on ROS v7.3.1. Can you please give me some insights on how to set up IPv6 on L2TP server? I have it set up on IPv4, when I connect to it using IPv6 it does not connect.
For the server role, I cannot see anything that would have to be set specifically to enable client connections via IPv6.
So post the export of the current configuration - don’t forget to obfuscate the public and global IP addresses. There are too many things that may be wrong to list them all.
Here you go
jul/02/2022 01:02:36 by RouterOS 7.3.1
software id =
model = RB4011iGS+
serial number =
add name=bridge1-LAN protocol-mode=none
set [ find default-name=ether1 ] name=""
set [ find default-name=ether2 ] name="ether2-ISP Backup"
set [ find default-name=ether3 ] name=
"ether3-Synology 820.3ad Link Aggregation"
set [ find default-name=ether4 ] name="ether4-Marv PC"
set [ find default-name=ether6 ] advertise=
100M-half,100M-full,1000M-half,1000M-full,2500M-full loop-protect=on
name="ether6-Marv PC"
set [ find default-name=ether7 ] advertise=
100M-half,100M-full,1000M-half,1000M-full loop-protect=on name=
"ether7-Marv PC"
set [ find default-name=sfp-sfpplus1 ] advertise=
1000M-full,10000M-full,2500M-full,5000M-full auto-negotiation=no
/interface l2tp-server
add name=l2tp-in1 user=vpn
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
/interface vlan
add interface=bridge1-LAN name=vlan11 vlan-id=11
add interface=bridge1-LAN name=vlan12 vlan-id=12
add interface=bridge1-LAN name=vlan15 vlan-id=1
add interface=bridge1-LAN name=vlan20 vlan-id=20
/interface bonding
add mode=802.3ad name="Synology DS 918+" slaves=
"ether3-Synology 820.3ad Link Aggregation,ether4-Marv PC"
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
/ip ipsec profile
set [ find default=yes ] enc-algorithm=aes-256,aes-128,3des
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256,sha1 enc-algorithms="aes-256-c
bc,aes-256-gcm,aes-192-cbc,aes-192-gcm,aes-128-cbc,aes-128-gcm,3des"
pfs-group=modp2048
add name=dhcp ranges=10.25.23.20-10.25.23.200
add name=pool-VLAN ranges=192.168.11.21-192.168.11.250
add name=vpn ranges=192.168.89.2-192.168.89.255
add name=ovpn-pool ranges=192.168.12.21-192.168.12.250
add name=pool-VLAN12 ranges=192.168.13.21-192.168.13.250
add name=pool-VLAN20 ranges=192.168.20.21-192.168.20.250
add name=pool-OVPN ranges=192.168.15.21-192.168.15.250
add name=dhcp_pool8 ranges=192.168.15.2-192.168.15.254
add address-pool=dhcp interface=bridge1-LAN lease-time=1d name=server-LAN
add address-pool=pool-VLAN interface=vlan11 lease-time=1d name=server-VLAN
add address-pool=pool-VLAN12 interface=vlan12 lease-time=1d name=
server-VLAN12
add address-pool=pool-VLAN20 interface=vlan20 name=server-VLAN20
add address-pool=pool-OVPN interface=vlan15 name=OVPN
/ipv6 dhcp-server option
add code=23 name=DNS value=0xfd000000000000000000000000000001
/ipv6 pool
add name=ULA-pool6 prefix=fd00::/64 prefix-length=64
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
add interface-list=LAN local-address=pool-OVPN name=ovpn remote-address=
pool-OVPN
set *FFFFFFFE dns-server=10.25.23.1 local-address=192.168.89.1
remote-address=vpn remote-ipv6-prefix-pool=IPV6
/queue simple
add max-limit=10M/10M name=queue-VLAN11 target=vlan11
add max-limit=20M/20M name=queue-VLAN12 target=vlan12
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/routing table
add fib name=to_ISP1
add fib name=to_ISP2
/tool traffic-generator port
add interface=sfp-sfpplus1 name=port1
add bridge=bridge1-LAN ingress-filtering=no interface=ether8
add bridge=bridge1-LAN ingress-filtering=no interface=ether9
add bridge=bridge1-LAN ingress-filtering=no interface=ether10
add bridge=bridge1-LAN ingress-filtering=no interface="Synology DS 918+"
add bridge=bridge1-LAN ingress-filtering=no interface=ether5
add bridge=bridge1-LAN ingress-filtering=no interface=l2tp-in1
add bridge=bridge1-LAN ingress-filtering=no interface="ether6-Marv PC"
add bridge=bridge1-LAN ingress-filtering=no interface="ether7-Marv PC"
add bridge=bridge1-LAN ingress-filtering=no interface=sfp-sfpplus1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
set accept-router-advertisements=yes max-neighbor-entries=8192
/interface detect-internet
set detect-interface-list=WAN internet-interface-list=WAN lan-interface-list=
LAN wan-interface-list=WAN
/interface l2tp-server server
set enabled=yes l2tpv3-ether-interface-list=LAN use-ipsec=yes
add comment=defconf interface=bridge1-LAN list=LAN
add comment=defconf interface="" list=WAN
add interface=vlan12 list=LAN
add interface=vlan15 list=LAN
add interface=l2tp-in1 list=LAN
/interface ovpn-server server
set auth=sha1 certificate=Server cipher=aes256 default-profile=ovpn enabled=
yes keepalive-timeout=120 require-client-certificate=yes
/interface pptp-server server
PPTP connections are considered unsafe, it is suggested to use a more modern VPN protocol instead
set authentication=pap,chap,mschap1,mschap2 enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=10.25.23.1/24 interface=bridge1-LAN network=10.25.23.0
add address=192.168.11.1/24 interface=vlan11 network=192.168.11.0
add address=192.168.13.1/24 interface=vlan12 network=192.168.13.0
add address=192.168.20.1/24 interface=vlan20 network=192.168.20.0
add address=192.168.15.1/24 interface=vlan15 network=192.168.15.0
add address=192.168.1.2/24 interface=ether10 network=192.168.1.0
add address=10.2.0.1/24 interface=wireguard1 network=10.2.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1d
/ip cloud advanced
set use-local-address=yes
/ip dhcp-client
add interface="ether2-ISP Backup" use-peer-dns=no
add interface="" use-peer-dns=no
add address=10.25.23.0/24 comment=LAN dns-server=10.25.23.1 gateway=
10.25.23.1 netmask=24
add address=192.168.11.0/24 comment=VLAN dns-server=8.8.8.8 gateway=
192.168.11.1
add address=192.168.13.0/24 gateway=192.168.13.1
add address=192.168.15.0/24 gateway=192.168.15.1
add address=192.168.20.0/24 gateway=192.168.20.1
set allow-remote-requests=yes cache-size=10240KiB servers=
1.1.1.1,1.0.0.1,2606:4700:4700::1111,2606:4700:4700::1001
/ip dns static
add address=10.25.23.20 disabled=yes name=marv-server
/ip firewall address-list
add address=192.168.10.51 comment=OPPO-F7 list="Family Safe Browsing"
add address=192.168.10.52 comment=OPPO-A5s list="Family Safe Browsing"
add address=10.25.23.30 comment=Galaxy-J7-Pro list="Family Safe Browsing"
add address=192.168.10.53 comment=Galaxy-A10 list="Family Safe Browsing"
add address=10.25.23.27 comment=CodeAlpha list="Adult Filter"
add address=0.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=10.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=100.64.0.0/10 comment="defconf: RFC6890" list=not_global_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=172.16.0.0/12 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.0.0.0/29 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.168.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=198.18.0.0/15 comment="defconf: RFC6890 benchmark" list=
not_global_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=not_global_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=bad_src_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=bad_src_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=bad_dst_ipv4
add address=224.0.0.0/4 comment="defconf: RFC6890" list=bad_dst_ipv4
add address=192.168.10.0/24 comment="Marv Admin" list="Marv Admin"
add address=192.168.10.1 comment=Router list=Router
add address=192.168.11.0/24 list="Marv Admin"
add address=192.168.10.48 comment="MSI Marv" list="Adult Filter"
add address=192.168.11.21-192.168.11.250 comment="VLAN 11" list=
"Adult Filter"
add address=192.168.10.46 comment="OPPO-F1 S" list="Family Safe Browsing"
add address=192.168.12.21-192.168.12.250 comment="VLAN 12" list=
"Adult Filter"
add address=10.25.23.28 comment="Elijah A52" list="Family Safe Browsing"
add address=14.169.204.14 list=ssh_blacklist
add address=10.25.23.29 comment="Luke A52" list="Family Safe Browsing"
add address=10.25.23.25 comment=Marv-ROG list="Adult Filter"
add address=10.25.23.23 comment="Marv Admin" list="Marv Admin"
add address=10.25.23.5 list=Router
add address=10.25.23.23 comment="Marv PC" disabled=yes list=
add action=add-src-to-address-list address-list="Port Scan Attackers"
address-list-timeout=1w3d chain=input comment="Port Scan Attackers"
protocol=tcp psd=21,3s,3,1 src-mac-address=!80:61:5F:0D:E4:25
address-list-timeout=5d chain=forward comment="Port Scan Attackers"
add action=accept chain=forward comment="Allow remote desktop" dst-port=3389
in-interface=all-ppp protocol=tcp
add action=fasttrack-connection chain=forward comment="Fastrack SFP+ Port"
connection-state=established,related disabled=yes hw-offload=yes
in-interface=bridge1-LAN
add action=fasttrack-connection chain=forward comment="Fastrack DNS TCP"
disabled=yes dst-port=53 hw-offload=yes protocol=tcp
add action=fasttrack-connection chain=forward comment="Fastrack DNS UDP"
disabled=yes dst-port=53 hw-offload=yes protocol=udp
add action=drop chain=input comment="Drop incoming DNS request from WAN"
dst-port=53 in-interface="" protocol=tcp
dst-port=53 in-interface="" protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="Allow L2PT / IPSec VPN access"
dst-port=1701,4500,500 in-interface-list=WAN protocol=udp
add action=accept chain=input comment=IPSEC-ESP in-interface-list=WAN
protocol=ipsec-esp
add action=accept chain=input comment=IPSEC-AH in-interface-list=WAN
protocol=ipsec-ah
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=accept chain=input comment=OpenVPN dst-port=1194 protocol=tcp
add action=accept chain=forward dst-port=3389 in-interface=all-ppp protocol=
tcp
add action=drop chain=input src-address-list="Port Scan Attackers"
add action=accept chain=input src-address-list=allowed_to_router
add action=accept chain=input disabled=yes protocol=icmp
add action=accept chain=input connection-state=established,related,new
disabled=yes
add action=accept chain=forward connection-state=established,related,new
disabled=yes
add action=add-src-to-address-list address-list="Trying to access router"
address-list-timeout=none-dynamic chain=input dst-address-list=Router
protocol=tcp src-address-list="!Marv Admin"
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
add action=drop chain="add action=drop dst-address-list=no_forward_ipv6 commen
t="defconf: drop bad forward IPs"" comment=
"defconf: drop bad forward IPs" src-address-list=no_forward_ipv6
add action=accept chain=forward comment="defconf: accept ICMPv6 after RAW"
protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ESP" protocol=
ipsec-esp
"defconf: accept all that matches IPSec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="Remote Desktop Connection"
in-interface="" protocol=rdp
add action=accept chain=output content="530 Login incorrect" dst-limit=
1/1m,9,dst-address/1m protocol=tcp
add action=add-dst-to-address-list address-list=ftp_blacklist
address-list-timeout=3h chain=output comment=ftp_blacklist content=
"530 Login incorrect" protocol=tcp
add action=add-src-to-address-list address-list=ssh_blacklist
address-list-timeout=1w3d chain=input comment=ssh_blacklist
connection-state=new dst-port=22 protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3
address-list-timeout=1m chain=input comment=ssh_stage3 connection-state=
new dst-port=22 protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2
address-list-timeout=1m chain=input comment=ssh_stage2 connection-state=
new dst-port=22 protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1
address-list-timeout=1m chain=input comment=ssh_stage1 connection-state=
add action=drop chain=input comment="drop ssh brute forcers" dst-port=22
protocol=tcp src-address-list=ssh_blacklist
add action=drop chain=input comment="drop ftp brute forcers" dst-port=21
protocol=tcp src-address-list=ftp_blacklist
"defconf: drop everything else not coming from LAN" in-interface-list=
!LAN
/ip firewall mangle
add action=change-ttl chain=prerouting disabled=yes new-ttl=increment:2
passthrough=yes
add action=mark-connection chain=output connection-mark=no-mark
connection-state=new new-connection-mark=ISP1_conn out-interface=
add action=mark-routing chain=output connection-mark=ISP1_conn
new-routing-mark=to_ISP1 out-interface=""
connection-state=new new-connection-mark=ISP2_conn out-interface=
"ether2-ISP Backup"
add action=mark-routing chain=output connection-mark=ISP2_conn
new-routing-mark=to_ISP2 out-interface="ether2-ISP Backup"
add action=masquerade chain=srcnat out-interface=""
add action=masquerade chain=srcnat out-interface="ether2-ISP Backup"
add action=dst-nat chain=dstnat comment="Family Safe Browsing" dst-port=53
protocol=udp src-address-list="Family Safe Browsing" to-addresses=
185.228.168.168 to-ports=53
protocol=tcp src-address-list="Family Safe Browsing" to-addresses=
add action=dst-nat chain=dstnat comment="Adult Filter" dst-port=53 protocol=
udp src-address-list="Adult Filter" to-addresses=185.228.168.10 to-ports=
53
tcp src-address-list="Adult Filter" to-addresses=185.228.168.10 to-ports=
53
add action=masquerade chain=srcnat disabled=yes out-interface=
"ether2-ISP Backup"
add action=dst-nat chain=dstnat comment="Open VPN" disabled=yes dst-port=1194
in-interface=all-ppp in-interface-list=all protocol=tcp src-port=1194
to-addresses=192.168.10.0/24 to-ports=3389
add action=accept chain=srcnat comment=
"defconf: accept all that matches IPSec policy" disabled=yes
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=
192.168.25.0/24
192.168.89.0/24
add action=src-nat chain=srcnat comment="Enable to access PLDT Onu"
dst-address=192.168.1.1 to-addresses=192.168.1.2
add action=dst-nat chain=dstnat in-interface="" protocol=tcp
src-port=3389 to-addresses=192.168.10.22
/ip firewall raw
add action=accept chain=prerouting comment=
"defconf: enable for transparent firewall"
add action=accept chain=prerouting comment="defconf: accept DHCP discover"
dst-address=255.255.255.255 dst-port=67 in-interface-list=LAN protocol=
udp src-address=0.0.0.0 src-port=68
"defconf: accept everything else from LAN" in-interface-list=LAN
"defconf: accept everything else from WAN" in-interface-list=WAN
"defconf: accept everything else from VPN" in-interface=all-ppp
add action=drop chain=prerouting comment="defconf: drop bogon IP's"
src-address-list=bad_ipv4
dst-address-list=bad_ipv4
src-address-list=bad_src_ipv4
dst-address-list=bad_dst_ipv4
add action=drop chain=prerouting comment="defconf: drop non global from WAN"
in-interface-list=WAN src-address-list=not_global_ipv4
"defconf: drop forward to local lan from WAN" dst-address-list=
192.168.10.0/24,192.168.11.0/24 in-interface-list=WAN
"defconf: drop local if not from default IP range" in-interface-list=LAN
src-address=!192.168.10.0/24
add action=drop chain=prerouting comment="defconf: drop bad UDP" port=0
protocol=udp
add action=drop chain=bad_tcp comment="defconf: TCP flag filter" protocol=tcp
tcp-flags=!fin,!syn,!rst,!ack
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,syn
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,!ack
add action=jump chain=prerouting comment="defconf: jump to ICMP chain"
jump-target=icmp4 protocol=icmp
add action=jump chain=prerouting comment="defconf: jump to TCP chain"
jump-target=bad_tcp protocol=tcp
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=fin,urg
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=syn,rst
add action=drop chain=bad_tcp comment=defconf protocol=tcp tcp-flags=rst,urg
add action=drop chain=bad_tcp comment="defconf: TCP port 0 drop" port=0
protocol=tcp
add action=drop chain=prerouting comment="defconf: drop the rest" disabled=
yes
add disabled=no dst-address=8.8.8.8/32 gateway=112.206.128.1 scope=10
add disabled=no dst-address=8.8.4.4/32 gateway=192.168.0.1 scope=10
add check-gateway=ping disabled=yes dst-address=0.0.0.0/0 gateway=8.8.8.8
routing-table=to_ISP1
add check-gateway=ping disabled=yes distance=2 dst-address=0.0.0.0/0 gateway=
8.8.4.4 routing-table=to_ISP1
add check-gateway=ping disabled=yes dst-address=0.0.0.0/0 gateway=8.8.4.4
routing-table=to_ISP2
8.8.8.8 routing-table=to_ISP2
add disabled=no dst-address=8.8.8.8/32 gateway=10.111.0.1 scope=10
add disabled=no dst-address=208.67.222.222/32 gateway=10.111.0.1 scope=10
add disabled=no dst-address=8.8.4.4/32 gateway=10.112.0.1 scope=10
add check-gateway=ping disabled=no dst-address=10.10.10.1/32 gateway=
208.67.222.222 scope=10
add check-gateway=ping disabled=no dst-address=10.20.20.2/32 gateway=8.8.4.4
scope=10
208.67.220.220 scope=10
add check-gateway=ping disabled=no dst-address=10.10.10.1/32 gateway=8.8.8.8
scope=10
scope=10
add disabled=yes dst-address=0.0.0.0/0 gateway=10.10.10.1 routing-table=
to_ISP1
add disabled=yes distance=2 dst-address=0.0.0.0/0 gateway=10.20.20.2
add disabled=yes dst-address=0.0.0.0/0 gateway=10.20.20.2 routing-table=
to_ISP2
add disabled=yes distance=2 dst-address=0.0.0.0/0 gateway=10.10.10.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=10.25.23.0/24,192.168.89.0/24,192.168.0.0/24
set api-ssl disabled=yes
/ipv6 address
add address=fd00::1/128 advertise=no comment="IPv6 ULA address" disabled=yes
add disabled=yes from-pool=IPV6 interface=wireguard1
/ipv6 dhcp-client
add add-default-route=yes interface="" pool-name=IPV6 request=
prefix use-peer-dns=no
/ipv6 dhcp-server
add address-pool="" dhcp-option=DNS disabled=yes interface=bridge1-LAN name=
LAN-dhcp6
/ipv6 firewall address-list
add address=::1/128 comment="defconf: RFC6890 lo" list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment="defconf: RFC6890 IPv4 mapped" list=
bad_ipv6
add address=2001::/23 comment="defconf: RFC6890" list=bad_ipv6
add address=2001:db8::/32 comment="defconf: RFC6890 documentation" list=
bad_ipv6
add address=2001:10::/28 comment="defconf: RFC6890 orchid" list=bad_ipv6
add address=100::/64 comment="defconf: RFC6890 Discard-only" list=
not_global_ipv6
add address=2001::/32 comment="defconf: RFC6890 TEREDO" list=not_global_ipv6
add address=2001:2::/48 comment="defconf: RFC6890 Benchmark" list=
not_global_ipv6
add address=fc00::/7 comment="defconf: RFC6890 Unique-Local" list=
not_global_ipv6
add address=::/128 comment="defconf: unspecified" list=bad_dst_ipv6
add address=::/128 comment="defconf: unspecified" list=bad_src_ipv6
add address=ff00::/8 comment="defconf: multicast" list=bad_src_ipv6
add address=fe80::/10 comment="defconf: RFC6890 Linked-Scoped Unicast" list=
no_forward_ipv6
add address=ff00::/8 comment="defconf: multicast" list=no_forward_ipv6
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6 after RAW"
protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=
33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/16
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept IPSec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept IPSec ESP" protocol=
ipsec-esp
add action=drop chain=input comment="drop incoming dns request from WAN"
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop bad forward IPs"
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
protocol=icmpv6
ipsec-ah
ipsec-esp
!LAN
add action=drop chain=input comment="Drop (invalid)" connection-state=invalid
add action=accept chain=input comment="Accept (established, related)"
add action=accept chain=input comment="Drop DHCP (>10/sec)" in-interface=
"" protocol=udp src-port=547
add action=accept chain=input comment="Accept external ICMP (10/sec)" limit=
10,5:packet protocol=icmpv6
add action=drop chain=input comment="Drop external ICMP (>10/sec)"
in-interface="" protocol=icmpv6
add action=accept chain=input comment="Accept internal ICMP" in-interface=
"!" protocol=icmpv6
add action=drop chain=input comment="Drop external" in-interface=
add action=reject chain=input comment="Reject everything else" reject-with=
icmp-no-route
add action=accept chain=output comment="Accept all"
add action=drop chain=forward comment="Drop (invalid)" connection-state=
invalid
add action=accept chain=forward comment="Accept (established, related)"
add action=accept chain=forward comment="Accept external ICMP (20/sec)"
in-interface="" limit=20,50:packet protocol=icmpv6
add action=drop chain=forward comment="Drop external ICMP (>20/sec)"
add action=accept chain=forward comment="Accept internal" in-interface=
add action=accept chain=forward comment="Accept outgoing" out-interface=
add action=drop chain=forward comment="Drop external" in-interface=
add action=reject chain=forward comment="Reject everything else" reject-with=
icmp-no-route
/ipv6 firewall nat
add action=dst-nat chain=dstnat disabled=yes dst-port=53 protocol=udp
src-address-list=Test to-address=2a0d:2a00:1::/128 to-ports=53
/ipv6 firewall raw
add action=accept chain=prerouting comment="defconf: RFC4291, section 2.7.1"
dst-address=ff02::1:ff00:0/104 icmp-options=135:0-255 protocol=icmpv6
src-address=::/128
src-address-list=bad_ipv6
dst-address-list=bad_ipv6
"defconf: drop packets with bad SRC ipv6" src-address-list=bad_src_ipv6
"defconf: drop packets with bad dst ipv6" dst-address-list=bad_dst_ipv6
in-interface-list=WAN src-address-list=not_global_ipv6
add action=jump chain=prerouting comment="defconf: jump to ICMPv6 chain"
jump-target=icmp6 protocol=icmpv6
"defconf: accept local multicast scope" dst-address=ff02::/16
"defconf: drop other multicast destinations" dst-address=ff00::/8
/ipv6 nd
set [ find default=yes ] advertise-dns=no disabled=yes other-configuration=
yes
add advertise-dns=no interface=bridge1-LAN other-configuration=yes
/ppp secret
add name=vpn profile=default-encryption service=l2tp
add name=ovpn profile=ovpn service=ovpn
add name=marv profile=default-encryption service=l2tp
/system resource irq rps
set sfp-sfpplus1 disabled=no
/tool bandwidth-server
set authenticate=no enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
/tool traffic-generator packet-template
add mac-protocol=ip name=packet-template1
I can see nothing wrong in L2TP settings, IPsec settings, nor ipv6 firewall settings.
I am a bit confused regarding the IPv6 address - I can see there is a DHCPv6 client but not connected to any particular interface, do you have any global IPv6 address attached to any interface at all?
Anyway, run /tool/sniffer/quick mac-protocol=ipv6 port=500,1701,4500 and try to connect the remote L2TP client - can you see anything in the sniff?
Yes it’s connected to an interface, I think I just accidentally deleted it when I’m editing the config export file.
Anyway, run > /tool/sniffer/quick mac-protocol=ipv6 port=500,1701,4500 > and try to connect the remote L2TP client - can you see anything in the sniff?
I did but when I try to connect via the IPv6 address on my vpn client on another network the error was IPv6 can’t be found.
IPv6 in general or the IPv6 address of the 4011? I.e. are we dealing here with “how to set up an L2TP server listening on an IPv6 address on Mikrotik” or with “why can’t my client use IPv6 to connect anywhere” question?
IPv6 of the 4011
Sorry for the confusion, it is
But since the client claims it cannot reach the address of the 4011, and you cannot see any packets from the client to arrive while sniffing at the 4011, it sounds more like the latter. Can you at least ping the IPv6 address of the 4011 from the client device?
Well this is weird I also can’t ping the IP address of the 4011. “Ping transmit failed general failure” but I think this must have to do something on my clients side rather than the 4011
So first, what does https://test-ipv6.com/ show on the client?
Second, what are the first 16 bits of the IPv6 address of the server you are trying to connect the client to, 20xx, fe80 or something else?
First 16 bits are still safely unsufficient to break your anonymity.
