Hi, sorry to ask this again! I had to reconfigure my router because I've locked myself out, and despite me having asked & solved the very same question in below linked thread, I cannot get it running again.
If I import the config into the Desktop Wireguard client, my single machine is connected to the VPN successfully.
But if I try to apply the same config in RouterOS, it does not perform the handshake. I went through the answer from Anav, to no avail.
So I think something is wrong with my routing.
Here is the full config.
Another thing I did not understand from Anavs last answer is how the nat rules are affected by adding wireguard_internet to the WAN list, maybe that is related to the problem.
[admin@MikroTik] > /export hide-sensitive
2023-09-09 22:52:42 by RouterOS 7.11.2
software id = xxxx-xxxx
model = RB760iGS
serial number = asdfsadfaasdf
add admin-mac=ab:cd:ef:...... auto-mac=no comment=defconf name=bridge
/interface wireguard
add comment="Home Internet" listen-port=51820 mtu=1420 name=wireguard_internet
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.0.100-192.168.0.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
/routing table
add disabled=no fib name=via-wg
add bridge=bridge comment=defconf interface=sfp1
/ipv6 settings
set disable-ipv6=yes
add interface=wireguard_internet list=WAN
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=mysuperdomainname endpoint-port=51820 interface=
wireguard_internet public-key="+X9y+AW/ci/BmGFKA5KETmGrBeF1OFWNOUA5JkmWMWo="
add address=192.168.0.1/24 comment=defconf interface=bridge network=192.168.0.0
add address=172.30.0.4/24 interface=wireguard_internet network=172.30.0.0
/ip dhcp-client
add address=192.168.0.0/24 comment=defconf dns-server=192.168.0.1 gateway=192.168.0.1 netmask=24
set allow-remote-requests=yes servers=9.9.9.9
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=
add action=accept chain=input comment="Allow incoming traffic to the wireguard service" dst-port=51820 protocol=udp
add action=accept chain=input comment="admin remote access" in-interface=wireguard_internet
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=
add action=accept chain=forward comment="internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" connection-nat-state=dstnat
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
add action=masquerade chain=srcnat disabled=yes out-interface=ether1 src-address=172.30.0.0/24
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wireguard_internet routing-table=via-wg scope=30
suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=2200
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp
src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/routing rule
add action=lookup-only-in-table disabled=yes src-address=192.168.0.0/24 table=via-wg
/system clock
set time-zone-name=Europe/Budapest
/system note
set show-at-login=no
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
[admin@MikroTik] >
Greetings
Thoru
