I am trying to connect a MikroTik Routerboard 153 (Level 4) WISP AP to a Vodaphone wireless router too extend my wireless connection to the office I have at the bottom of the garden
I have been successful at loading the password into the Routerboard and it is logging onto the Vodaphone wirless router. I can ping out onto the web from the Routrboard via the ping section of winbox
But If I try too ping the router board or the vodaphone router from my computer I get a general failure
DHCP is enabled on he vodaphone router
This is the result of an ipconfig
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Paul>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::e921:670a:c628:e4bf%67
Autoconfiguration IPv4 Address. . : 169.254.228.191
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . : home
Tunnel adapter Local Area Connection* 12:
Tunnel adapter isatap.{12A66675-5017-4A94-B3C1-C5B363DFDCC7}:
Tunnel adapter 6TO4 Adapter:
Any help would be appreciated thanks
Feklar
August 15, 2011, 2:13pm
2
Have you bridged the Ethernet interface with the wireless interface? In general, each interface on a RouterBoard is it’s own separate routed interface unless you tell it otherwise.
No I haven’t. I have only a very limited experience with networking and have only got this far with trial and error and help from forum etc
I can see the ‘bridge’ option in win box is this what you mean? can you help me in setting this up or point me too a tutorial that will tell me
Thanks for the reply I appreciate it
Feklar
August 15, 2011, 3:41pm
4
/interface bridge add name="WLAN Bridge"
/interface bridge port add bridge="WLAN Bridge" port=ether1
/interface bridge port add bridge="WLAN Bridge" port=wlan1
This bridges the two interfaces together in software making them act as one layer2 interface instead of two separate layer3 interfaces.
Hi thanks for the reply sorry I am not well versed on these matters
I take it that this code is used in a new terminal window in Win box ?
I inputted the first line and got a new WLAN bridge in the interfaces window
The other two lines give me an answer no such argument (port)
Feklar
August 15, 2011, 5:22pm
6
I have no idea what your interface names are. You’ll have to replace them with the appropriate names yourself.
Apologies again for my ignorance
I have tried the names of my interfaces I.E 19db-pac-rootenna and lan and it still gives me the no such argument (port)
However I have gone too the Bridge / Port tab in Winbox and added these two interfaces there. This has resulted in an IP address being assigned to my laptop within the range of the Vodaphone router
The micotic is showing 192.168.1.144 and the laptop is showing 192.168.1.36 and now has the right default gateway IE the Vodaphone router
However I can ping the Routerbox but not he Vodaphone router or acess the web am I on the right track
Feklar
August 15, 2011, 6:21pm
8
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 2.9.35 (c) 1999-2006 http://www.mikrotik.com/
Terminal vt102 detected, using multiline input mode
[paul@MikroTik] > interface wireless export
jan/01/2000 02:05:47 by RouterOS 2.9.35
software id = PUQ5-3TT
/ interface wireless
set 19db-pac-rootenna name=“19db-pac-rootenna” mtu=1500
mac-address=00:0B:6B:57:0D:83 arp=enabled disable-running-check=no
radio-name=“cbrowne-pkelly” mode=station ssid=“” area=“”
frequency-mode=manual-txpower country=ireland antenna-gain=0
frequency=2412 band=2.4ghz-b/g scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no
security-profile=vodaphone disconnect-timeout=3s on-fail-retry-time=100ms
preamble-mode=both compression=no allow-sharedkey=no comment=“”
disabled=no
/ interface wireless nstreme
set 19db-pac-rootenna enable-nstreme=no enable-polling=yes framer-policy=none
framer-limit=3200
/ interface wireless manual-tx-power-table
manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,1
2Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17
/ interface wireless security-profiles
set default name=“default” mode=none authentication-types=“”
unicast-ciphers=“” group-ciphers=“” wpa-pre-shared-key=“”
wpa2-pre-shared-key=“” eap-methods=passthrough tls-mode=no-certificates
tls-certificate=none static-algo-0=none static-key-0=“” static-algo-1=none
static-key-1=“” static-algo-2=none static-key-2=“” static-algo-3=none
static-key-3=“” static-transmit-key=key-0 static-sta-private-algo=none
static-sta-private-key=“” radius-mac-authentication=no group-key-update=5m
add name=“vodaphone” mode=dynamic-keys authentication-types=wpa2-psk,wpa2-eap
unicast-ciphers=tkip,aes-ccm group-ciphers=tkip,aes-ccm
wpa-pre-shared-key=“” wpa2-pre-shared-key=“J759NS3636SQG”
tls-mode=no-certificates tls-certificate=none static-algo-0=none
static-key-0=“” static-algo-1=none static-key-1=“” static-algo-2=none
static-key-2=“” static-algo-3=none static-key-3=“”
static-sta-private-key=“” radius-mac-authentication=yes
group-key-update=5m
/ interface wireless align
set frame-size=300 active-mode=yes receive-all=yes
audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 ssid-all=no
frames-per-second=25 audio-min=-100 audio-max=-20
/ interface wireless access-list
add mac-address=00:00:00:00:00:00 interface=19db-pac-rootenna
authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0
private-algo=none private-key=“” comment=“” disabled=no
/ interface wireless snooper
set multiple-channels=yes channel-time=200ms receive-errors=no
/ interface wireless sniffer
set multiple-channels=no channel-time=200ms only-headers=no receive-errors=no
memory-limit=10 file-name=“” file-limit=10 streaming-enabled=no
streaming-server=0.0.0.0 streaming-max-rate=0
[paul@MikroTik] >
normis
August 16, 2011, 8:48am
10
why are you using a version released 5 years ago?
2.9.35
I used the router on a WAN wireless network but moved out of range of this some time ago. I have only recently started trying to use the unit again (with some difficulty) for the use I have for it now. If I can get it too operate I will upgrade the software
Feklar
August 17, 2011, 3:36pm
12
You are using the wrong mode for the radio card, change it.
Read the wiki example of Station modes I posted.
http://wiki.mikrotik.com/wiki/Manual:Wireless_Station_Modes#Mode_station
Your other option is to set up the device to be a router and NAT out of the wireless interface.
The menus on the example that you posted do not mach the ones available on my OS so I am upgrading the OS and will then change the settings
I will let you know how I get on
