Hi All,
My first post here, I’ve just picked up the networking bug, and its a MikroTIC one !. I think someone here can help me please ?
I need to connect two 5GHz SXT’s, assign IP’s, with one in Bridge mode, and the other in Station Bridge mode.
The SXT’s will act like a very long ethernet cable, (point to point link) and allow me to connect to the internet in my workshop
They will need to connect using layer 3, IP, not Bridging. The SXT Bridge’s ethernet interface will connect to my router, and be a DHCP client.
so, the SXT Bridge will be a DHCP client, while the SXT station bridge will be a DHCP server.
I’m going to use the following IP config -
10.10.10.1/30 = WLAN Int.(Bridge)
Awaiting IP address from DHCP = Ethernet Int.(Bridge)
10.10.10.2/30 = WLAN Int. (StationBridge)
192.168.200.0/24 = Ethernet Int. (StationBridge)
When I build this, the ethernet interface of the Bridge is assigned an IP of 10.0.0.2/24, and the gateway is 10.0.0.1/24
Now i’m unsure if i assign this gateway to which interface of the station bridge ?, do i add any IP route here also ??
Any suggestions, would be welcome, THANKS !!
Qnet72
