Connect two Mikrotiks via cable to provide WDS
in my flat the WLAN coverage of one router is not sufficient (Walls are very thick) . So I want to connect two routers (Both Mikrotik) via a patch cable to provide the same WLANs.
What are the options mikrotik routers offer to do achieve this ?
Thanks in advance for your hints!
Nothing to it.
Don’t use WDS, set the APs to different channels with the same SSID and you should have no problems.
If you only have one wireless device you can use the same channel without issue.
