Connect USB RB2011UiAS-RM
Hello
I search for a driver for USB-Port of the RB2011UiAS-RM Router. There is no Network access for configuration on the Router possible now. I have make a fail configuration of the Router. I want to save the configuration (in ASIC) the Router now.
User109
Recover the routerboard with netinstall.
See on my webpage for procedure: http://www.wirelessinfo.be/index.php/mikrotik/pages/netinstalle
Hello plisken,
thanks for your Manual of Ethernet booting.
Ralphs109
Is the problem be solved?
yes other wise. The Ethernet booting doesn’t worked, because my firewall has blocked the packet’s. It’s a company Notebook, so I can’t switch off the firewall. My solution was to reset the RB2011 and configure again, but the configuration doesn’t work. See here http://forum.mikrotik.com/t/rb2011uias-rm-no-internetconnection-on-switchports/76670/1
