connect usb storage to RB411
Hello ,
I’m connecting a 8GB USB to the RB411
but what does “Type” mean? - why I get unknown in it?
[admin@Korenron] > /store print
Flags: X - disabled, A - active
 #   NAME                 TYPE                 DISK                 STATUS
 0   test                 (unknown)            usb1                 backup
also how can I save files in the usb?
Thanks ,
Have you format the usb drive?
http://www.wirelessinfo.be/index.php/mikrotik/pages/transparant-proxy
Here I show you step for step how to use a usb hard drive with transparent proxy
yes I have format the disk – also try with another DOK ,same thing.
The storage “Type for” which you used.
As example web-proxy
I understand your question is not well
o.k. I have format it again - first from computer, then from router - and now it’s good
now my question is -
I want the USB to be a storage for FTP and not web-proxy
how can I do this?
I want to be able to upload to the RB files (that will be saved in the USB)
Thanks,
