Hi. I have a wap r ac lte kit and I want to try to connect the gopro with you the router I configured the wlan1 in Station mode and connect to wifi gopro and the wlan2 are in ap Bridge mode in wlan2 works fine the problem are the gopro I can’t reach over the wlan2 I can’t ping gopro but show in wlan1 that are connect to gopro. What’s is the issue? Best regards
You mean gopro has a wifi and you connected to it through wlan1? If yes then use station bridge, not station mode.
The problem are that gopro dont work with station brigde…
My mistake, i meant station pseudobridge…
