Connect with 802.11n to NV2 AP
Is it possible to make a Virtual SSID on an AP that will work with 802.11 legacy and another SSID that work only with nv2 at the same AP at the same time?
Virtual AP does not work with NV2 protocol?
Virtual AP uses the protocol settings of the actual interface. Equipment at 802.11 is not compatible with NV2.
sorry if you misunderstood, I am weak in English.
